Callies LSc Stroker Crank ?
Old 12-23-2009, 07:19 AM
sgm98ws6's Avatar
Default Callies LSc Stroker Crank ?
Anybody used or heard of these / any sponsor carrying them?
These LSc CompStar 5140 Forged Crankshafts by Callies are specically designed for moderate (575 HP & 600 ft lb torque) applications. Designed to withstand the rigors of light-duty truck applications, C-Series components are also excellent in moderate performance installations. All GM Gen III engines ranging from the 5.3L truck block to the 6.2L L92/LS3 are perfect candidates.
Just thought maybe this would be decent for a budget 408 build...
Old 12-23-2009, 07:30 AM
marksboy7's Avatar
Got one in the LS3 427 sitting in my barn right now thats waiting on completion. I've read of many people using them and from what I've seen a lot of the sponsors carry callies cranks and rods.
Old 12-23-2009, 07:38 AM
sgm98ws6's Avatar
I was just kinda curious because this crank is a hair over 500 and the actual compstar is around 900... I know they make good products. Just kinda wondering if it will work for me. I was just under the impression that they were just released recently in the last few weeks.
Old 12-23-2009, 07:50 AM
marksboy7's Avatar
Ok no I haven't heard of a new compstar crank. I have the original compstar crank.
Old 12-23-2009, 08:00 AM
sgm98ws6's Avatar
yeah they came out with a new one thats around 525 from a site that is not a sponsor. It says they added it december 5th 2009. My builder saw it in one of the GM magazines.
Old 12-23-2009, 08:01 AM
99blancoSS's Avatar
We use the C series in budget builds
Old 12-23-2009, 08:03 AM
sgm98ws6's Avatar
I know what they say they are rated for, but I will be over it by a bit. How are these cranks holding up?
Old 12-23-2009, 08:28 AM
99blancoSS's Avatar
Most aftermarket cranks are overkill for 90% of the street cars being built. It all comes down to application and true intended use of the car. We would use the C series and then compstar or go to a Dragonslayer or Magnum XL depending on what you were really going to do with it.
Old 12-23-2009, 09:37 AM
KCS
Moderator
KCS's Avatar
Can you get them with an LS7 snout?
Old 12-23-2009, 09:48 AM
99blancoSS's Avatar
I'll check
Old 12-23-2009, 10:01 AM
sgm98ws6's Avatar
Well looks like i will be using it in my 408 L92 build with a little bit of nitrous... guess I will find out how good they are.
Old 12-23-2009, 10:03 AM
LS1 BU's Avatar
I think they are underated. I figure if a stock crank can hold up to 700 rwhp on many turbo applications. This would handle at least that or more. I have one of these going into a 418 ls3 with spray.
Old 12-27-2009, 04:23 AM
99blancoSS's Avatar
Still waiting to hear back from Callies KCS, holiday is causing a few delays
Old 12-27-2009, 11:32 AM
Tom@SpeedInc's Avatar
negative, their is compstar LS7 snout 4340 cranks though as i'm sure you know.
C-Series has 2 stroke sizes, 3.825" and 4.000"
made from 5140 Forging
We took one past 800rwhp with twin turbo, no problem
Old 12-27-2009, 11:47 AM
99blancoSS's Avatar
Callies will and does make us what we want so I'll let you know
Old 12-27-2009, 08:28 PM
sgm98ws6's Avatar
Thanks Fraser. Should be good then with my 408 and 200 shot...
Old 12-27-2009, 10:34 PM
I wouldn't loose sleep over it
Compstar also sell LSc I beam connecting rods,
I like these for stock rebuilds. 6 1/8 on center rods, bushed small end.
some of the lesser expensive I beams arn't bushed (ie scat)
The LSc parts original intent was to 're-power' GM full size trucks,
where they may see a overhaul at 150k miles, give them a torque increase.
Every year at PRI i've always asked Eagle and Scat if they would make 5140
parts for LS engines, had no intrest in doing so, glad Callies did so.
Old 12-28-2009, 11:55 AM
KCS
Moderator
KCS's Avatar
Gentlemen, thanks for the updates.
I agree, it's good to see more affordable parts like this. 1500hp capable 4340 cranks seem to be overkill for a 500hp 408ci street engine. Businesses could also probably get back customers who may have been excluded due to the economic environment we're in now.
Old 12-28-2009, 12:06 PM
99blancoSS's Avatar
Yep toally agree, we've been able to price a 408 short block very well with the Callies C series crank and Eagle or Scat rods. Its less money than an Eagle crank as
Old 12-29-2009, 02:23 AM
sgm98ws6's Avatar
99blancoSS Can you get me some prices on the LSc crank and rods for my 408?
Quick Reply: Callies LSc Stroker Crank ?
