Turbo Cam
Turbo Cam
I was going to just use the stock LS2 cam on my setup for a while with my L92 heads but it looks like the stock L92 springs are not even up to task for the LS2 cam so i have decided to just do it all at once and get a cam.
I am looking for recommendations on cam specs as i plan to get a custom ground one.
Build will be as follows:
2005 GTO
4L80e 3200-3400 stall
LS2 block
Stock 3.622 stock
Forged rods
10:1 compression ratio
Stock L92 heads
L76 intake manifold
SD tune
Twin rear mounted turbos 66mm .48 exhaust a/r
Stock exhaust manifolds into gutted stock mids
2.5" back to turbos
Going to be running 73@4bar ls3 injectors with 1:1 reg.
A fairly heavy methanol injection setup.
I am looking for 750-800rwhp as a max
Cam needs to have a healthy sounding idle and i do not want to take a large hit in MPG as i would rather it be efficient in the cruising RPMs and then use the turbos to overcome any restrictions this type of cam may have.
I may prefer a smaller LSA that of a N/A cam to lower Dynamic compression ratio but I'm looking for opinions
thanks
2005 GTO
LS2 block
Stock 3.622 stock
Forged rods
Stock L92 heads
L76 intake manifold
SD tune
2.5" back to turbos
thanks
