Tax return on the way help me choose heads and clutch
I can finally afford heads and the clutch up grade I need.
What do you think about the following package? Will I lose low end power? Is this the best bang for the buck? Should I stay with the stock rockers? Should I worry about changing out my oil pump to a high flow?
PRC 220cc 5.3L Stage 2.5 CNC Ported Heads
ALL NEW 220cc Precision Race Components 5.3L Stage 2.5 CNC Ported Cylinder Heads!! $1134.99
Stage 3 $1179.00
Complete Monster Clutch Kit with 28LB Flywheel
Tick Performance Adjustable Clutch Master Cylinder Kit
Tick Performance Remote Clutch SPEEDbleeder Line
GM Style Slave Cylinder (F-Body Type)
Throwout Bearing
Pilot Bearing
Clutch Alignment Tool
There are no other pieces to the puzzle
Stage 3 $1179.00
Throwout Bearing
Pilot Bearing
LS1Tech Premium Sponsor
For a budget oriented ported GM casting, the PRC heads are hard to beat! That paired up with the less expensive 5.3L casting (as compared to the LS6's), makes the Stage 2.5 5.3's a great option for the budget build! They will work well with your TorquerV2 camshaft as well, and give you a nice little bump in compression to pull a bit more power out of the combo as well!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
My car has 65,000 miles do you recommend changing out the rockers and oil pump? Will my car still pass inspection?
Also I'm not sure what you mean by less expensive casting, will these heads handle my 125 nitrous shot? With the spray I will be right at 523 HP. / 550 TQ
Thanks Matt,
Also I'm not sure what you mean by less expensive casting, will these heads handle my 125 nitrous shot? With the spray I will be right at 600 HP.
The 5.3's will handle that shot of nitrous without any issues as long as your fuel supply and tune are up to it!
__________________
I'd go with a pump for sure. I'd also modify my stock rocker with Comp's trunion upgrade kit instead of buying an aftermarket rocker. We offer that kit for about $130, and in under an hour of work, you have the benefit of the light weight and good strength the GM rockers provide, without the worries of needle bearings puking out into your engine
We've got lots of tax day sales coming very soon. The cylinder heads are already at the special pricing, but we'll be adding other items very shortly!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
I agree, I ran a buddy of simliar weight and same tuner in his afr/v2 frc and slowly pulled away from him with my prc5.3 stage2.5 heads and smaller stealth II cam for half the price...
Check out the PRC aftermarket casting heads!
__________________
I suggest you do a little more reading on cyllinder heads and WHY the ARF's adn trickflows are more expensive and the benefits you recieve from spending the extra money.
I'm not knocking prc heads or any other. I have seen lots of different head combos at my local track. I have raced lots of cars who claim you don't need AFR heads or The new king trick flow. But,I never had a car at the track or raced one that out did my times or pulled me in a race. I had(yes had) A very close to stock weight ws.6,m6 car with my 230lbs(190lbs now) running close to 10's na. I also had a non ported intake,everything hooked up,stock th-stat and no e.w.p. I still believe the AFR and trick flow heads are the top. You get what you pay for. You should see what trickflow did to my boys 383ci ls1. he's pumping out better then some 402ci numbers and times with them.
JESTER-you seemed to spend the money for the intake and nice headers. Don't skimp on the heads. They cost more for a reason,not just performance.
Do a lot more research on the heads. See if the Trick Flow or AFRs are worth the investment to you. I think they will be better overall even with similar flow numbers coming from a ported stock casting.
It really all depends on a customers goals. The PRC 215 heads will make more power than the stock ported castings, but the extra cash isn't something everyone wants to let go of. I would easily put the PRC 215s against any aftermarket casting head in the county. That being said the Stage 2.5 5.3l heads & stage 2.5 ls6 heads are really hard to beat for the $$$!
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
A very competent porter with a stock casting can make more power than an AFR. Have first hand seen it done. The PRC's are probably THE best bang for your buck head out there. Personally I would go with the 5.3's taken down to a 60cc chamber and run a .040 gasket and use a cam in the mid 230's.
I guarantee you will make 440+ through a 6 speed on a dynojet.
Should also trap around 95-97mph in the 1/8 mile.
