If you had to choose...
Old 01-27-2010, 11:59 PM
Dutchman427's Avatar
Default If you had to choose...
between and LS7 and a LS9, which one would you go for and why?
Old 01-28-2010, 01:30 AM
the_merv's Avatar
Depends on what your goals are..
Old 01-28-2010, 06:46 AM
Busted Knuckles's Avatar
LS7 'cause I already have the block for one
Seriously, I'm not ever planning to go over 1000hp with mine, probably not over 900 with spray or boost. I like the longer cylinder sleeves, steel main caps and bore size.
Old 01-28-2010, 09:18 AM
KCS
Moderator
KCS's Avatar
LS9: Larger head bolts, better casting, plus it's already supercharged.
Old 01-28-2010, 09:22 AM
99blancoSS's Avatar
+1
Old 01-28-2010, 10:20 AM
Gannet's Avatar
None of the above.
The LS9 is a PITA to hook up, and the LS7 has weak cylinders and pistons.
For $15-21k, get a purpose-built motor.
Old 01-28-2010, 10:29 AM
the_merv's Avatar
What about a LS7 Block, fully Forged/Balanced, Cammed, just a NA Build at about 11.5:1 Comp..
That should hold out.
Old 01-28-2010, 11:04 AM
99blancoSS's Avatar
Yep if your sticking n/a then its not a bad way to go... although with the price of the block you could get a re-sleeved LS2 and be a little better off
Old 01-28-2010, 11:26 AM
the_merv's Avatar
Honestly I would go with one of the Warhawk ones if I was going to spend the money..
