building ls3 427 stroker, which heads/cam combo?
Old 02-02-2010, 11:36 AM
general23cmp's Avatar
Default building ls3 427 stroker, which heads/cam combo?
What would you recommend? Going with NA, pump gas, flat tops w/valve reliefs...High power, but streetable.
Debating L92s, ported L92s, TF 235s, AFR 225 or 245s, etc....
Cam will be dependant on above.
Thanks.
Old 02-02-2010, 12:17 PM
Jimbo'sZO6's Avatar
Best bang for the buck would probably be an L92 headed motor. Now that people are getting cam profiles figured out for these it might just be the way to go. I went with AFR 225's on my 416 simply because I already had a FAST 90/90 and I got a super deal on a barely used set of CNC'd AFR's.
Jimbo
Old 02-03-2010, 09:07 AM
What cam companies, sizes, etc. wouldbe good for an L92 headed motor? I want streetable (meaning enough vacuum for brakes and decent idle), but high power/torque as well. I didn't realize they required (or preferred) different profiles than the norm.
Old 02-03-2010, 09:12 AM
formula17's Avatar
Read up a little on LS3/L92 cams their is a TON of information on this site, Just use the search. You will then find who to talk to about a cam for these heads.
Old 02-03-2010, 10:04 AM
Jimbo'sZO6's Avatar
Patrick G or Ed Curtis would definitely be able to help you out with cam selection.
Old 02-03-2010, 12:28 PM
99blancoSS's Avatar
We can put together a combination for you, we have an HKE version of the L92 coming out shortly
Old 07-28-2011, 04:06 PM
Wildcobra's Avatar
how did the build go
Old 07-28-2011, 05:20 PM
nwalton29's Avatar
Too lazy to search, so which is better?, TFS 235's or ported L92's. Using 102/102.
Old 07-28-2011, 07:51 PM
6.0monsta's Avatar
Tfs 235
Old 07-28-2011, 09:03 PM
litle88's Avatar
LPE Ls3 heads with hollow valves and patriot gold spr
Old 07-28-2011, 09:12 PM
litle88's Avatar
LPE Ls3 cncd heads with hollow intake valves, inconel exhaust valves and patriot gold sprIngs for 1600 are hard to beat in my book.
Flow numbers.
http://www.lingenfelter.com/images/L...CL92intake.pdf
http://www.lingenfelter.com/images/L...L92exhaust.pdf
Old 07-28-2011, 11:31 PM
CAMSTER's Avatar
Default head
the Mast performance part #510-302;
have 254cc int port volume
flows 360cfm at .600 int lift
and 251cfm on the exhaust,
have 3/4 deck thickness
will turn circles around the rest. nuff said
Old 07-28-2011, 11:52 PM
FlamingTA's Avatar
Very nice but also 3k..
Old 07-29-2011, 10:05 PM
COPO9560's Avatar
The flow values on the MAST heads are on a 4 inch bore - be careful as many other suppliers rate theirs on 4.125 bore which makes flow numbers look better. If nitrous is in your future, the MAST head has a thicker deck than a ported GM does. You get what you pay for.
Old 07-30-2011, 06:19 PM
Tireburnin's Avatar
Advanced Induction ported L92s.
See my results in my signature.
Old 07-30-2011, 06:20 PM
WKMCD's Avatar
There are a couple of ways (BorexStroke) to get to 427 CI and that will make a difference what heads may work best. You never mentioned how you're getting the cubic inches.
Old 08-02-2011, 02:08 PM
1CAMWNDR's Avatar
With an LS3 (block I am assuming) it is either 4.065" stock bore and a 4.125" crank, or a 4.07" honed bore and a 4.100" crank.
Quick Reply: building ls3 427 stroker, which heads/cam combo?
