ls3 block
ls3 block
im lookin at a ls3 block its a killer deal but ive been told that i shouldnt build a turbo motor with the block because its been bored to 4.080 i was just wondering if you guys think its safe to build a turbo motor out of it
Strictly your decision... I've got an L-92 block that needs boring (my factory sleeves are so far off-center there's only 0.080" showing in places!) and I'm concerned about doing a NA build with it. I'm still cringing at the price for Darton dry's, so I may give boring a try first.
LS1TECH Sponsor
Ls3
Most of the LS3 blocks I have seen will go .020" over no problem. I would not go crazy with the boost on these blocks with stock liners regardless.
I have been sleeving quite a few LS3 blocks with Darton dry liners lately. Some blocks have the cast in stock liners not on bore center or vertical to the deck surface. This results in walls that are thick on one side and thin on the other. You would end up cracking the liner and the block if you run into detonation with your tune or with too much boost for the available octane.
Steve
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Steve Demirjian
Oceanside, Ca.
760-630-0450
LS1Tech Premium Sponsor
We have to look really carefully at the LS3 blocks we use in our customers builds that's for sure. I've seen big hp from a LS3 block, but you have to be careful with them for sure. I bet I have 3-4 of them that will need sleeves from Steve before they can be run!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
LS1TECH Sponsor
LS3 block family
Still the same deal with these blocks in the LS3 family of blocks LS3, LSA, LS9
The new LT1 block hopefully will be better. It appears GM is using a casting method around the sleeves on these new blocks similar to a lot of the import blocks I sleeve. Import sleeve placement is far better than on the GM blocks to date.
Steve
Steve
__________________
Steve Demirjian
Oceanside, Ca.
760-630-0450
Steve Demirjian
Oceanside, Ca.
760-630-0450
Steve
Steve
That is farther than I would allow any of our motors to go. We will allow for 4.070" max before it is nescessary for a sleeve. I definately agree with the guys at TSP above. Be careful with it, It is not impossible but not the best idea to use so large.
I know plenty of guys with 416's in NA and FI Ls3 strokers. You gotta take it to a shop that specializes in LsX's and the right rotating assembly. If you stroke it make sure you get a quality coated piston skirts because they do rock at BDC. But nothing that will zap longevity though, just precautionary.
One of the things we do @ TSP that nobody machining LS blocks can do is cnc digitize the blocks & determine bore locations relative to blueprint. When a typical machine shop bores a block they bore based on the existing bores location. GM never puts the bore in exactly the right location. What we do on blocks here is digitize the block & determine if it meets our requirements for being correctly machined to blueprint. if the block doesn't meet those requirements we send it back & get another block.
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
If I understand what he is saying properly, GM fails 99.9% of the time and the bore ends up off of center of the sleeve. They get it as close as they can if not dead center if GM was close with the original bore.
