How Much for Forged Pistons & Rods in a LS3
Picked up a LS3 with 200 miles on it from a wrecked 2009 Corvette.
Would like to install forged pistons and rods in it along with ARP hardware and swap out the 58 reluctor wheel with a 24 wheel.
Anybody have an idea of cost. I want to keep the stock crank and maybe drop the compression down to 9.5 to 1 and throw on some doble springs.
Thanks.
Thanks.
Your best bet would be to get a complete rotating assembly from one of the sponcers, like TSP.
http://www.texas-speed.com/shop/item...d=887&catid=88
I'm looking for stock cubes as I would like to go FI.
LS1Tech Premium Sponsor
You can run the stock crank if you're not going to stroke it. The stock crank holds a good bit of power! So really you're looking at a set of good pistons (I'd go Wiseco), and a nice set of rods for which I like Callies. Pistons with ring set are on special for $759.99 and the rods are just under $550. Then you'd just have to get a machine shop to do the balancing on the rotating assembly, machine the block, etc and you'd be ready to rock!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I'm not going for big power, just looking for 600 RWHP. Some guys seem to get lucky and run forever on stock block and others blow up in a week.
Thanks for the info. Just seeing what my options are at this point.
I just did the same thing with my L92. Wiseco pistons K1 rods, all new bearings, gaskets, polished crank, balanced and all the other little crap that goes with a rebuild, and LS2 timing cover since I went non vvt on the build and im into it $3200 or so. Not bad since I got a running L92 for $350 to start with
Sent ya a reply, thanks.
Thanks for the info. I picked up a 2009 LS3 Long Block from a wrecked vette with 200 miles on it, however I paid a lot more than $350.
I already have a brand new forge 416 LS3 sitting at home, actually I'm in the midst of selling it. I have been going back and forth over SC or Turbo system. If I go turbo the smaller cubes works better with the available systems out there.
Thanks,
Tony
That's a thought too or just throw on the blower or turbo and do some praying that it doesn't blow up.
I'm not trying to set any records, just trying to have a fun street set-up with a little bit of extra kick.
Thanks,
Tony
Shouldn't have to rebalance it, at least if used the Katech bolts.
I think I'm going to end up selling it, and just buying a forged set-up as pricing to forge the motor is $3K + shipping cost.
I'm half tempted to throw my forged 416 (LS3) in it and sell off the motor in the car plus the LS3..
I got someone ready to buy the LS3 forged motor already , and I really just want a stock cubed LS3 in case I go turbo.
I got lots of time to think things over as I won't be working on it again until September.
Need to finish up the body, suspension and interior first before hitting the drive train.
I'll have to pick up a set of Katech's.
I'm doing the same but moving from an iron 408 to an LS3. Since I have the replacement motor still out, just getting the required pieces into it. In the not too distant future, there's a pretty good chance it'll be supercharged this time around (instead of turbos) so I keeping an eye out for set of forged pistons and plan on maybe keeping the stock rods and going with an LS1 crank. Even with just pistons, I agree all the little pieces add up quick.
Thanks and good luck on your end...
I got (3) motors in my garage (2) more motors in the vettes along with two transmission set-ups (C6 Z06 2008 Tranny & Differential) and a complete A4 set-up.
I garage looks like a tuner shop.
Still got get "Zenak's" sled off my lift so I can move on to my projects. We re-did his suspension with Moog & Spicer ball joints, VBP tie rod ends, SKF bearings, Pfadt Poly Bushings with zerts and a bunch of other maintenance items.
Wish I had more time to relax and play with the cars but my job has had me hopping for the last few months.
What made you switch from PTK to SC ?
If I did pistons and rods, I would send the whole motor out to be done and have the crank keyed too.
