PVD Coating for Engine Parts
I am in the process of putting an engine together and would like to have some of the engine parts (Valves, Piston Pins) PVD Coated with an Anti-Wear Coating. Does anyone know places that offer this coating??
Thanks LS1Tech for all your help!!!!!
PVD is Physical Vapor Deposition which is different than common chemical coatings. Is that what you're speaking of? Balzers is a good source for this, but their are others. Keep in mind, the parent material has to be finished with an extremely fine RA. If not, you might as well be running a carbide file up and down the guides, pin bores, etc.
Because of the finish required, Precision Products in NC would be a good place for pins. They do the great work in a variety of materials with DLC (tradename Casidium) coatings. As for Valves, that's a similar situation and plan on letting your high end (Xceldyn, DelWest, etc.) valve manufacturer spec out for you. Keep in mind, these aren't cheap, but you're paying for the super-finish in addition to the PVD.
Swaintech is the best. http://www.swaintech.com/store.asp?pid=10539
Some company does the coating for them...I just would like to know who does it?
Is Casidium the name of the anti friction coating?
Thanks for the help!!!!
Thanks for the PM!!! I was given the name of the company that offers the coating for Xceldyne Valves...but they are located in Belgium. I would rather work with someone in the US!
Thanks again for everyone for the help!!!
