Cam sensor for 97 C5
I have been having problems getting my 97 to idle correctly with my L92 (w/cam) since it's been in the car. I had the earlier reluctor wheel put on the motor prior to installing it (the motor) in the car, but was only recently made aware that the cam has some sort of different piece which triggers the cam sensor....could someone who knows explain this to me....I need change the cam sensor plate?
LS1Tech Sponsor
If it's an LS3 motor you have to change the Cam gear from the 4 point wheel to a single point.If you left the stock(LS3) wheel there it will have a hard time starting and idling.
The easiest thing to do was to buy the conversion harness from LPE and just leave that LS3 reluctor wheel.They have a conversion box that plugs in real easy.
Thanks for your help.
