TF CNC 225's or PRC 227?
Old 02-15-2010, 11:32 PM
GT-OH's Avatar
Default TF CNC 225's or PRC 227?
Looking to get the most power out of this LS2 . I am already running a VRX-5 cam, SLP LT, and a SLP UDP. Will also be adding a FAST 102, FAST 46# injectors and a Spintech exhaust. Now it is just a matter of which head? I want to reach that 500 RWHP.
Old 02-16-2010, 01:33 AM
Fifedogg's Avatar
For the price those PRC 227's Look quite nice. I would like to see these heads with a side by side comparrison... Everyone on here knows both company's are great especially TFS.
Old 02-16-2010, 02:52 AM
MASS seller approved
smok'nZ's Avatar
tfs if you can afford them
Old 02-16-2010, 08:22 AM
LSXFORMULA99's Avatar
i am looking at the prc's for my car. they are really nice and make some good power.
Old 02-16-2010, 02:14 PM
kickassT/A's Avatar
wont make it there with those headers no matter what head
Old 02-16-2010, 02:21 PM
GT-OH's Avatar
I hope to prove you wrong
Old 02-16-2010, 03:16 PM
kickassT/A's Avatar
kooks 1 7/8", TFS 225's, and a ported fast will get you close. i did it on a customer's car with a 238/242 cam but it had jessels and an ewp on it
Old 02-17-2010, 09:11 PM
GT-OH's Avatar
Any more opinions?
Old 02-19-2010, 08:52 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
The advantage to the PRC 227 is it features a smaller chamber option for exactly this application. You can't mill the TFS enough & keep your p/v good to get compression where you need to be. The PRC 227 head will keep good p/v thanks to the little bit smaller valve, and it will start with a 62cc chamber so your compression is in good shape without milling!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 02-21-2010, 05:01 PM
GT-OH's Avatar
Anyone else want to chime in, I plan I buying this week.
Old 02-21-2010, 05:45 PM
pmj341's Avatar
I have the TFS 225's with a 61cc Chamber, however I have a 4.125 bore and a small cam, on the Ls2 stock bore might be a problem with P/V as prev mentioned!!
They work great with my combo!!
Old 02-21-2010, 07:18 PM
dickieirish's Avatar
Thunder has the TEA TF 225 for a really good price. Has dual springs all the goods you would need to get to your goal of 500rwhp. I have a mild size cam and a ported fast 92. With the size of cam you have, I have know doubts that you will reach what you want. When my car was tuned it put down 497rwhp before the smoothing factor and it was 90 degrees+ with TX humidity. These heads or ETP would do it but ETP is more cash. TEA 225 are around $2395.
Old 02-21-2010, 07:20 PM
There is a guy on LS1gto that had a 60+hp gain with the TEA 225's.
Old 02-26-2010, 01:59 PM
GT-OH's Avatar
Decided to go with the TF 225's. Will post up when I get some #'s.
Quick Reply: TF CNC 225's or PRC 227?
