Questions on Dampers/Harmonic Balancer
A few quick questions about dampers....
Are the Trans Am dampers the same as the LQ4 dampers? I was told that the cranks are the same so that would lead me to believe they are.
I will be getting rid of the A/C so if the dampers that I get happens to include A/C provisions, would it cause issues if I don't hove the belt? I know it sounds like a strange question, but I'm not sure if the missing tension from the unused A/C belt would cause problems
Also, what is the aprox increase of HP with the 10% and 25%? IIRC the 10% give 7hp what about the 25%?
I am looking at the following dampers, which would you suggest?
SLP Harmonic Balancer Underdrive Pulley LS1 F-Body
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
Chevrolet LS1 Camaro SFI damper Power Bond Firebird
Pontiac GTO LS1 25%UD Powerbond SFI Harmonic Balancer
Thanks guys!
DM
Thanks guys!
DM
