L92 & LS3 engine
L92 & LS3 engine
Does a L92 engine have the same crank and flexplate as the LS3,wondering if a L92 6.2 engine will bolt in a car the same as a LS3 engine ? Are they different at all internally ? Thanks
All you will ever want to know about the L92 and LS3 is in the link attached which is a sticky in this section btw
https://ls1tech.com/forums/generatio...-l92-info.html
