coating
It's not the coatings, it's usually the prep. You can coat it yourself, just be sure to sandblast the surface first for adherence, and get the best quality coatings.
Piston Coatings are designed to:
• Prevents cold start piston seizures
• Friction reduction causing reduced temperatures
• Quiets piston noise or rattle
• Increases piston and cylinder bore life
• Increased fuel efficiency
• Smoother running engines = Increased power and Longer life
I would shy against doing it yourself unless you really know what you're doing. Getting the proper coverage will be a little ruff but the blasting part is what could really mess you up... BUT Thats just me personally
They are fine. Do homework. Katech is lighter, what I run now. You have to weigh them yourself really, the weight specs are never right. And, yes you better know what you are doing with coatings, etc, true with anything.
