Ls3 heads which patriot springs??
Old 03-04-2010, 12:28 PM
jasonsnova's Avatar
Default Ls3 heads which patriot springs??
Ok i have ls3 heads, and a texas speed 225/230 .617/.614 cam, i'm gonna order patriot gold springs but i dont know if i need part 8401 or 8401-b???
says the 8401-b has .565 ID spring bases, i tried to call them but the tech dept is at a show and wont be back till next week. anyone have any idea? thanks
Old 03-04-2010, 02:56 PM
jasonsnova's Avatar
never mind ....broke out the heads and gauges...they are going by valve guide dia. i needed the .505 ones!
Old 03-04-2010, 04:53 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
you'll need .505" Those springs should do just fine with that camshaft. Back in the day before we drastically upgraded our spring kit line we used the same spring as what your looking at. They lasted pretty good at lower lifts like that & should be good for a solid 30k miles.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Quick Reply: Ls3 heads which patriot springs??
