Issues with HS rockers & AFR 205s
Ive read that people have had to grind down the Harland Sharp 1.7 Rockers to fit AFR 205 heads. Is this true? Anybody know what is all involved in making them fit?
-Geoff
-Geoff
I have them on my AFR 205's as well. I did need to shim them to get a good wipe pattern and then needed to clearance inside the valve covers but they fit the heads fine. You need to obtain the correct wipe, then measure for the pushrod to get the correct lifter preload.
