L92 CAM and other info to get to 540-560 hp
What is the most power I can get with a stock 08 escalade L92 adding a cam with stainless works 1 7/8" headers. Also what cam would work best? 3200# car, track/street car. Looking for high end power I like to keep revs up around a track. If I stroke with cam what kit? And what kind of power can I expect. I saw a thread stating over 500 hp from cam alone with l92, but called texas and was told only 50 over stock which would be 453. And stroker kit only 50 more. So 503 with stroker and cam.
I am running the cam in my sig (Livernois Stage III, I think) and make the power noted to the rear wheels. My engine is a stroked LS2 with L92 heads and L76 intake. I am also running Kooks headers and x-pipe.The heads have a little clean-up and I think the chambers are 64cc.
I was running a more symmetrical cam with smaller LSA (112) and made more topend power but reversion made driveability at the lower rpms a real PITA. Do a search on my posts and you should come across my dyno with both cams.
So how is it that LS3's with cam swaps make insanely high power yet L92's only make 450? Granted the L92 intake is a weakeer performing item so ditch that for an LS3 intake and your set.
I'd call someone else for your cam. Try Patrick G on here he'll custom spec one for ya for cheap and tell him your goals and he'll get you there. Just be sure to tell him your final hp goal and be as clear as possible about your whole build in his request sheet.
I'm doing a GMPP Intake and Holley 780 or Demon 750/850. SW Headers, Valve springs and retainers, perhaps manley, and having Patrick G design a cam for me. Ditching VVT and using front cover from LS3, pretty sure thats the only part I need to swap to get rid of VVT with Cam. Using MSD 6LS controller
