Can someone tell me the valve drop on a stock L92 head? - LS1TECH
Thread Tools Search this Thread
Old 04-22-2010, 02:36 PM   #1
hirdlej's Avatar
Default Can someone tell me the valve drop on a stock L92 head?
I'm just hashing through some calculations and wanting to know what the stock free valve drop is on an untouched L92 head. I'd also be interested to know for those of you running the L92 heads on a LQ4 shortblock, what's your PTV clearance like? (please state cam specs as well)
hirdlej is offline   Reply With Quote
Old 04-24-2010, 01:34 PM   #2
LS1Tech Premium Sponsor
Richard@WCCH's Avatar
Just checked on a new "out of the box" casting:
Intake -
Solid stem (L92) .133"
Hollow stem (LS3) .133"
Exhaust -
Solid stem (L92) .160"
Sodium valve (LS3) .160"
Production tolerances will move them up or down a couple of thou.
Richard
Richard@WCCH is offline   Reply With Quote
Old 04-24-2010, 01:46 PM   #3
Quote:
Intake -
Exhaust -
Richard
Richard,
Do you have a theory on why the L92s have dropped a valve? Do you see the valve or bad lock as the culprit? Have you seen these happening on LY6 engines too?
thanks,
Jim
Jimbo1367 is online now   Reply With Quote
Old 04-25-2010, 07:23 PM   #4
zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz zz
Old 04-26-2010, 11:48 AM   #5
cam
I've seen a few threads pop up with the dropped valve problem and there was no smoking gun that I saw. Im chalking it up to crappy workmanship or insufficient valve springs for those particular failures until someone proves otherwise. Lots of guys running these heads on stock valves without issue
cam is offline   Reply With Quote
Old 04-26-2010, 12:43 PM   #6
Quote:
Originally Posted by Jimbo1367 View Post
Richard,
thanks,
Jim
The "valve drop" the OP was refering to is the dimension from the shallow edge of the valves to the deck of the head. It's a vertical measurment that is used to calculate valve to piston clearance.
We've not seen many L92 heads with broken valves. Both the solid stem and hollow LS3 valves seem to be holding up nicely.
Richard
Old 04-26-2010, 02:07 PM   #7
LS1 Tech Administrator
Patrick G's Avatar
Richard,
What is the valve drop on one of your CNC ported L92/LS3 heads? With many people interested in running them with larger cams and no valve reliefs, it would be good to know how much room we're dealing with. Thanks!
Patrick G is offline   Reply With Quote
Old 04-26-2010, 03:12 PM   #8
Richard
Richard,
I figured that out. I didn't mean to hijack the tread, but I figured you might return to comment again and you to enlighten me/us.
thanks,
Jim
Old 04-29-2010, 11:32 PM   #9
Quote:
Originally Posted by Patrick G View Post
Richard,
Excellent question Patrick. Our Stage 2 L92 heads with machine finished chambers have the following valve drop specs (with minimum surface milling):
Intake - .135"
Exhaust - .205"
I'll post up specs for our Stage 3 heads over the weekend.
Richard
Old 05-02-2010, 10:38 PM   #10
Patrick G's Avatar
Intake - .135"
Exhaust - .205"
Richard
Wow, better than stock valve drop. That helps for guys not wanting to fly-cut. One of your competitors is selling a ported LS3 head that only had .089" free valve drop on the intake side (making it impossible to run anything larger than a cam in the 210s at .050").
Old 05-02-2010, 11:27 PM   #11
hirdlej's Avatar
A stock 243 head is around .160" valve drop so the L92's are a tighter fit........
Old 05-04-2010, 03:49 PM   #12
LS6
LS6's Avatar
informative thread
LS6 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
wtb ported ls3 or l92 heads or maybe stock ls3 or l92 heads heads bigfatls6 Parts Wanted 2 02-15-2012 06:26 PM
Stock l92 heads RPM limit nahasapeemapetalon Generation IV Internal Engine 12 01-30-2008 03:11 PM
L92 Valve Angle supersix Generation IV Internal Engine 10 12-13-2007 08:15 PM
LS7 with L92 heads? GMW-CSL Generation IV Internal Engine 5 05-16-2006 04:14 PM
Tags
cherokee, drop, engine, engines, free, grand, head, hollow, jepp, l92, ls2, ls3, reliefs, stem, stock, valve, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
