head gasket thickness/823-LS3 heads on 6.0 - LS1TECH
Thread Tools Search this Thread
Old 04-24-2010, 05:18 PM   #1
Default head gasket thickness/823-LS3 heads on 6.0
Hello, Iron 6.0 block with LS2 rotating assembly (stock flat top pistons) and #823 heads off a stock,crate LS3. I have a cam spec'ed with stock .054 gaskets, at 10.36 compression. I am now thinking of getting thinner gaskets to squeeze a bit more compression. BUT...stock ls2 pistons poke out the block @.009 as measured and how thin a gasket can I go before killing the "quench"?......or hitting some thing? I plan on redlineing this @ 7100rpm.........such as .035 gasket minus .009 thou only leaves .026 thou clearance. Should I just stick with stock .054 gasket or mill the heads? I will check but I think my piston to valve clearance will be O.K.
badjonny is offline   Reply With Quote
Old 04-30-2010, 12:28 PM   #2
Default anyone?
I dont want to spend the money to mill, I'm just trying to get the most out of stock heads, may as well build it with the thinnest reasonable gaskets. Still burning premium pump gas but would like to bump compression up to. Maybe I'm just "splitting hairs" and it wont make any real difference?
Old 05-03-2010, 10:57 PM   #3
3pedals's Avatar
I have very limited experience with the ls motors, but generally, less than .035" piston to head, is too tight for anything less than a limited use race motor. .040" is perfect for a street motor. my .02
3pedals is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
pushing limits stock 6.0 dogsballs Carbureted LSX Forum 182 12-12-2016 10:52 PM
Head Gasket Decision themealonwheels Generation III Internal Engine 6 05-01-2014 12:25 PM
Bad calculations? Cthulu Advanced Engineering Tech 5 03-06-2014 07:09 PM
Pushrod length question/suggestions stockblock85_22 Generation IV Internal Engine 5 03-11-2013 03:36 PM
Stock GM MLS Head Gaskets?? NeverT00fast Generation III Internal Engine 24 01-17-2007 09:43 AM
Tags
60, 823, cylinder, gasket, gaskets, head, heads, ls, ls1, ls2, ls3, lsx, milled, thickness, thinnest
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
