Need a few part numbers to put an LS3 in my F-body
Old 04-24-2010, 10:05 PM
JimMueller's Avatar
Default Need a few part numbers to put an LS3 in my F-body
I'm still looking for these:
- Cam sprocket gear to use a 3-bolt cam with a 24x reluctor. I think I read I can use one from a 2005 GTO? I'd prefer the part number though.
- After reading a lot on folks breaking their timing chains in the LS3 about a year ago, I need to know if there's been a reliable solution. I had planned on using a LS2 chain, the LS3 chain tensioner, and re-using my non-SFI ATI crank underdrive pulley from my LS1 motor. Looking for recommendations on the correct combination of parts that doesn't require a double-row chain, spacing the oil pump out, etc.
Thanks!
Old 04-25-2010, 11:27 AM
Vesper TA's Avatar
Thanks!
Here is the cam sprocket I ordered thru GM Performance.
"Part# 12576407
Camshaft Spocket. Fits LS1, LS2 and LS6. 1X camshaft gear. Three bolt design, uses (3) of P/N 12556127."
Old 04-28-2010, 07:31 PM
JimMueller's Avatar
If I wanted to use an ATI Super Damper, do I use the one listed for the F-Body/GTO, or the one listed for the LS1/LS2/LS6/LS3 Corvette?
Old 04-28-2010, 10:14 PM
SOMbitch's Avatar
You match the pulley to the rest of the accessories you are running. For instance the vette pulley fits tighter to the block and wouldn't line up with F-body accesories if that is what you are using.
Melling is now machining their pump housing different and using inset housing bolts that no longer requires shimming the pump to clear the double row TC. You Just need to make sure you are getting the newer design and not an old one that has been sitting around. Best of both worlds IMO...
Also somebody on here was selling the C5R single chains that are no longer made IIRC but are extremely strong. SDPC maybe??? ICRS anymore..... Katech had them at one time but I don't think have any more....
Old 04-29-2010, 07:29 PM
JimMueller's Avatar
Katech still sells the C5R chains. The $400 ATI Super Damper isn't exactly in the budget, any reason I can't use a new LS1 balancer pulley?
Old 04-30-2010, 07:11 PM
SOMbitch's Avatar
[QUOTE=JimMueller;13260296]Katech still sells the C5R chains. The $400 ATI Super Damper isn't exactly in the budget, any reason I can't use a new LS1 balancer pulley?[/QUOTE]
Sounds like you want somebody else to confirm this but match a F-body balancer to F-body accessories or vette pulley to vette accessories etc... and you are good......It all depends on the accessories you are using as to your balancer choice.....
Old 05-05-2010, 09:51 AM
JimMueller's Avatar
Will the LS1 fuel rail be compatible with the LS3 intake? I know I need spacers to re-use my LS1 injectors, but which fuel rail?
Old 05-09-2010, 04:50 PM
JimMueller's Avatar
Helped perform the pre-assembly yesterday. Pistons are .0105-.011 out of the hole, now we need we can really make progress on this... so I need to order parts, and I don't want bad surprises during assembly
This appears to be my master list of what I need to build the LS3 motor. I'm using mostly GM stuff because unless I get my Fast92 and LS1 heads sold I won't be able to afford the common upgrades. Some items are just really old and I'd like to replace them since it doesn't cost much (like the wires).
Looking for confirmation that I have the correct part numbers to mate the LS1 harnesses and accessories to the LS3 motor. Crank already has a 24x reluctor.
Code:
Description	                         Manufacturer	Part number	Unit cost
Block, bare (incl caps, bolts, cam brngs)GM	        12602691	1200
Main bearings	                         Federal Mogul	152M	        118.13
Crankshaft	                         GM	        12597569	125
Rod Bearings	                         Clevite	CB663H	        66.18
Connecting Rods & ARP 2000 rod bolts	 K1	        CH6125ALLB-LSL-8519
pistons	                                 SRP	        279593	        479
cam	                                 Comp Cam	Custom	        407
lifter guide kit	                 GM	        17803305	16.8
lifters	                                 GM	        12499225	121.95
head gasket (x2)	                 GM	        12610046	23.87
cylinder head set	                 GM	        12598594	900
head bolts	                         GM	        17800568	21.6
valvesprings	                         PAC	        1518	        188.8
pushrods	                         Manton
valley cover	                         GM	        12570471	84.86
intake manifold	                         GM	        12602477	249.99
timing chain	                         GM	        12586482	32.36
timing chain tensioner	                 GM	        12626407	26.12
timing cam sprocket	                 GM	        12576407	27.03
timing cam sprocket bolt (x3)	         GM	        12556127	1.72
Oil pump	                         GM	        12586665	93.99
oil pickup tube seal	                 GM	        12557752	4.55
oil pan, race baffle (optional)          Improved Racing		200
oil pan gasket	                         GM	        12612350	23.19
oil pickup tube girdle	                 BRP	        LS1-G	        19.95
front cover	                         GM	        12600325	69.15
rear cover gasket	                 GM	        12574293	21.63
balancer pulley	                         GM	        SLP100221	61.47
Balancer bolt	                         GM	        12557840	3.23
L92 Throttle Cable Adapter	         SLP	        SLP12509	66.99
Fuel Rail spacer	                 Katech	        KAT-A4674	24.99
fuel rail	                         GM	        12633511	162.18
Cam & Knock Sensor adapter harness	 Katech	        KAT-4750	59.99
MAP sensor adapter harness	         Katech	        KAT-4751	33.95
water pump gaskets (x2)	                 GM	        12610311	5
Racetronix fuel system (w/ BGK8)	 Racetronix	135-F98-FPK	229.5
Spark plugs (gapped to .035)	         NGK	        50-TR6	2.25
spark plug wires (optional)	         GM	        12495519	55
Morel bar lifters, Katech pump & chain, ARP head bolts & ATI Super Damper would all be in there if I could get these old parts sold
Quick Reply: Need a few part numbers to put an LS3 in my F-body
