Low Oil Pressure With New Motor
I've got a brand new 402 stroker motor that we just finished installing into my 2000 C5 Corvette. It's an LS2 block with an Aviad dry sump system. The filter is on a remote mount with a pressure regulator on it.
When we first fire it up cold, it's making 50-60 psi at the factory oil pressure sensor, but once it warms up, it's down to 25-30 psi at idle. We're seeing roughly 10 psi more on a guage installed at the regulator than indicated at the back of the block.
We're unable to adjust it above 30 psi with the regulator at idle once it is warmed up.
Could this be indicative that the barbell or galley plug are missing? Would it be able to make that much psi cold if either of these were missing?
We're thinking we need to go to a different pulley on the dry sump pump but I want to rule out other potential problems first.
Thanks,
Alan
Thanks,
Alan
Thanks for the replies!
Yes, oil pressure rises with RPM.
Oil is Joe Gibbs 15W-50 Break In Oil.
Spoke to my engine builder this morning and he says the barbell was definitely installed.
Looks like we're going to try a smaller pulley on the dry sump pump.
Thanks!
Alan
Thanks!
Alan
LS1Tech Premium Sponsor
Whoever built/assembled the engine should have a sheet with all the specs and clearances it was set up to on it. I'd check it out first thing and that'll help rule out and/or solidify any assumptions/variables.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Very true, I had the same concern with the LS7 I bought from Jon, turned out I needed to run thicker oil, because of this awesome Florida heat.
And if it gets even hotter 250-260F i´m seeing sometimes 14-16psi@idel
but i´m in Iceland and here is not hot weather it´s cold....
so should i use thicker oil, then what oil.....+
I so hope it´s not bad o ring or similuar to that......
Baezi
Temp??
I´ve got TPS 402 3K on it and using 10-40w havoline and when i starte the car up cold it is above 40psi 40-50 both cruising and near 40@idel , then when the engine is gone hot around 220F it´s lower or 25-35psi cruising and raises a bit while reving... goes down to 20psi@idel
Baezi
Baezi
Are you SURE the temp gauge is accurate??
Water or oil temps, either is too high.
i installed a texas speed 346 in a camaro from day one it only made 25psi at a hot idle.... the motor has been going for 4 years now with zero problems and he sprays the daylights out of it.....
Sorry to revive such an old thread, but we finally determined what the problem was and I wanted to post in case it helps someone else.
The problem was due to the fact that we plumbed the oil cooler into the pressure line instead of the scavenge side of the dry sump system and we were seeing 30-40 psi loss from the cooler.
We bypassed the cooler and now we can get over 80psi at the factory sensor (cold, before adjusting the bypass).
