LS1 heads on L76 block
Old 04-27-2010, 10:56 AM
Y2KSS's Avatar
Default LS1 heads on L76 block
Can I run my ported 98 LS1 heads and cam on a L76 block after removing the VVT?
Old 04-27-2010, 11:19 AM
cam
cam's Avatar
They will bolt on but the stock LY6 heads are the same as L92 heads and will flow more than your ported 98 heads will so why change them?
Old 04-27-2010, 01:34 PM
Y2KSS's Avatar
I was wanting to use my LS6 intake setup for now.
Old 04-27-2010, 02:51 PM
cam
cam's Avatar
All of that will bolt up so if you want to run it you can.
Old 04-27-2010, 03:46 PM
Y2KSS's Avatar
What would the approximate compression ratio be?
Old 04-27-2010, 05:31 PM
cam
cam's Avatar
No idea. You'd have to CC your combustion chambers to see what they are and calculate it out. Things like head gasket eetc all come into play with compression ratio. If everything is stock you'll be in the 10:1 region
Old 04-28-2010, 08:12 AM
Y2KSS's Avatar
Thanks, I was just trying to get an idea.
Quick Reply: LS1 heads on L76 block
