5.3 ?? Carb and NOS
5.3 ?? Carb and NOS
I currently run a sbc in a heads up 10.5 class. We have new rules that allow NOS on 335 cid and less. Plate system with 65 jet. Will these blocks and stock cranks hold 13:1 + NOS. What type head would this comb like? Is it hard to run a powerglide behind one of these?
Thanks
Parker
Thanks
Parker
check out the carb section, for more carb related LS stuff. To answer your question, I beleive the stock rotating assy with forged pitons added, would hold all kinds of nitrous and big compression. use the stock heads and send them in for a cnc work over. Glide is easy to put behind it, just as any gm auto: you need a .4" crank spacer between the crank and flexplate, and maybe slot the converter holes, thats about it.
