Aviad LS7 oil pan insert
Has anyone ever run the Aviad LS7 oil pan insert? I guess you remove the stock windage tray fom the engine completely, and run this in the pan, from what I can understand, it helps to direct oil directly into the pickup for the suction side of the stock pump, and then mounts it's own windage tray that is inside the pan rather than on the main caps.
I'm considering it. My engine builder just showed it to me tonight when I picked up my bottom end.
