370 build ?s
370 build ?s
Ok I have done 2 different setups.... now trying to see what are my options and possibly what kind of power im looking at!
Any help/suggestions on a setup would help thanks!
first setup
Block - GM LQ9 Iron block
C.I - 6.0l 370
Stroke - stock 3.622
Crankshaft - Stock LS crank
Rods - Stock 6.098
Pistons - Diamond Pistons LS1 Forged Flat Top Piston set w/ -2cc Valve Reliefs
Rings - Diamond Racing Ring Set, 4.030 Bore
Head Gaskets - Cometic LS Multi Layer Steel Gasket 4.030 Bore
2nd setup is about the same but a bit cheaper
Block GM LQ9 Iron block
C.I 6.0l 370
Stroke 3.622
Crankshaft Stock LS crank
Rods 6.098
Pistons Mahle LS1314030F04 - Mahle PowerPak Piston and Ring Kit
Rings Included with powerpak
Head Gaskets Cometic LS Multi Layer Steel Gasket 4.030 Bore
Now head options are either a slight port job on some 5.3 heads and bigger valves like stock size ls1 valves or some manely vavles
or might get some 243s with slight port job!
first setup
C.I - 6.0l 370
Rods - Stock 6.098
C.I 6.0l 370
Stroke 3.622
Rods 6.098
I had a 370 with ms3 car went 9.78in the 1/4@ 138mph on a 200 shot with a mild tune.
had diamond pistons-2cc,compstar rods, patriot stage 3 heads. milled to 60cc 12-1 compression
The first setup you have is the same thing im building right now im almost done except i have a 630 610 233-233 dur with a fast 90mm intake and long tubes with a borla cb hoping for 425 to the tire but im to scared to spray it even with the diamond piston's
