What Timing Chain Do I Need? - LS1TECH
Thread Tools Search this Thread
Old 02-25-2011, 10:40 PM   #1
Default What Timing Chain Do I Need?
I've got a 2011 Colorado with the 5.3 (LH9). I'm planning a cam swap with a 210/218 .551/.551 Crane 3-bolt cam. My stock setup has a 1-bolt cam with VVT. I already have a new non-VVT front cover with cam sensor and a set of LS6 springs. So what timing set do I need? I'm thinking a LS2 set will work but want to be sure. Need help!!!
P.S. Keeping the VVT is not an option so please don't try to talk me out of it.
Thanks!
TonyVette is offline   Reply With Quote
Old 02-25-2011, 11:04 PM   #2
TransWS6Am's Avatar
I'm pretty sure you need the x4 cam sprocket ls3 timing set.
TransWS6Am is offline   Reply With Quote
Old 02-26-2011, 08:09 AM   #3
litle88's Avatar
I also believe it's the x4, but you should also think about changing that Ls6 spring for a better after market piece. Your pretty much making them out. I had on my hotcam with 1.8 Harland sharps and I started getting valve float on the dyno for a retune. Just my .02
litle88 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
VVT delete without cam swap. Help please! 1BADWS6@STENOD Generation IV Internal Engine 1 12-23-2014 01:46 PM
3 bolt cam on 2011 VVT Silverado need some advice sleepy_boy1 Generation IV Internal Engine 4 11-12-2012 01:36 PM
5.3L please help! cgo Conversions & Hybrids 4 02-04-2012 10:35 AM
Questions on running VVT with Boost? turbinesurgeon Forced Induction 9 01-01-2012 03:56 PM
Tags
2011, 210218, 416, 53, 551, cam, chain, colorado, crane, float, lh9, ls, ls3, swap, timing, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
