6.0 pushrod - LS1TECH
6.0 pushrod
Thread Tools Search this Thread
Old 03-05-2011, 03:44 PM   #1
Default 6.0 pushrod
What is the stock length of 6.0 pushrods I need to order chromoly ones
92gearhead is offline   Reply With Quote
Old 03-05-2011, 03:52 PM   #2
TJ
should be 7.400
TJ is offline   Reply With Quote
Old 03-05-2011, 04:24 PM   #3
LSXHawk's Avatar
Quote:
i told u they were 7.4
LSXHawk is offline   Reply With Quote
Old 03-05-2011, 05:35 PM   #4
You said I believe they are that length. Like you weren't sure
Old 03-05-2011, 07:50 PM   #5
10 Second Truck Club
67SS509's Avatar
Stock truck 6.0 had bigger base circle cam and are 7.380 lenght. If you change cam to aftermarket or LSX cam use a 7.40
67SS509 is offline   Reply With Quote
Old 03-06-2011, 12:59 PM   #6
You should always measure. If the heads have been milled, block decked, rockers from here, lifters from there, measure, measure, measure.
hotswap is offline   Reply With Quote
Tags
60, length, long, ls, ls2, push, pushrod, pushrods, rod, size, stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
