how much power does this motor make??
so a freind of mine built a motor im thinkin about buyin for a side project. its an 05 6.0 block with 02 lq9 pistons rods and crank, hellfire rings, arp rod bolts, comp lifters, a .620 lift cam , comp springs, hardened pushrods, ported l92 heads, ls3 intake w/ stock 92mm TB, LS7 injectors with dynatech longtubes. and a yank 3200 stall convertor, how much power have you guys seen a setup like that make jus curious??
i was hoping for a bit over 5 i guess nelson did a mail order tune for him and said the motor should make 530ish flywheel
oh and pat G specd the cam but i dont remember what he told me the LSA and duration was
