whats the difference between these 2 cams?
Old 09-10-2011, 08:13 AM
ThunderZ28's Avatar
Default whats the difference between these 2 cams?
1st cam was a comp 235/247 .65?/.65? 113+3 XER(i believe)
2nd cam is a comp 239-247 .620/.632 113+3 HR
whats the difference?
I cant find either one of these on comps website..
both are custom grind cams...( hence the reason I probably cant find them)
just curious..
Thanks
Old 09-10-2011, 04:48 PM
ThunderZ28's Avatar
anyone?
Old 09-10-2011, 08:21 PM
STAR's Avatar
It seems like you are comparing LSL lobes to LSK lobes.
235/247 .621/.624 LSL lobes
235/247 .648/.656 LSK lobes
By looking at the lift numbers you can see the LSK lobes are way more aggressive for the same duration.
Quick Reply: whats the difference between these 2 cams?
