ls3 stroker w/ gto oil pan cover / scraper not fitting
Old 09-10-2011, 08:58 PM
anotheraznguy's Avatar
Default ls3 stroker w/ gto oil pan cover / scraper not fitting
so just got my stroker kit of 4.000 and there was a slight issue the oil pan cover. it is hitting the rod bolts and not even clearing..
for those that have gone stroker.. do you attempt to space it down / modify this one by cutting holes out or is there an aftermarket one?
Let me know guys.. Thanks
Old 09-10-2011, 09:01 PM
LSX-coupe's Avatar
Just space it down with two washers.
Old 09-10-2011, 09:33 PM
thank you.. works very good.. just very tight tolerence between the cover and the pan...
Old 09-10-2011, 10:00 PM
TurboAv's Avatar
I think we used 3 washers with my 4" crank.
Old 09-11-2011, 03:17 AM
DietCoke's Avatar
Do it once, do it right, don't ever have issues.
http://www.byunspeed.com/product_inf...ducts_id=14987
Old 09-12-2011, 10:54 PM
litle88's Avatar
Hey diet, I think the mast tray is either not sold any longer or it hasn't hit the streets cause the link doesn't work and mast doesn't show a price. But I'll be buttoning up my stroker this week and I'm in the same boat so I need some info on this too, and what's the deal with using washers and the effects of the dip stick?
Old 09-12-2011, 11:28 PM
DietCoke's Avatar
It works again, their website was down. You can order it from mast directly as well.
Add horsepower and get superior protection for your GM LS stroker engine with Mast’s all-new Black Label windage tray. The custom engineered contours optimize oil return to the sump while providing optimum protection against oil splashback. The Mast Black Label windage tray (P/N 401-015) fits all GM LS oil pans except 4th Gen F-Body that require a shorter tray (available soon from Mast Motorsports) and is ideal for racing or street/strip applications. The windage tray clears up to a 4.250” stroke crankshaft with H-beam connecting rods, is compatible with multiple pickup tubes, and accepts factory GM windage tray nuts. Each Mast Black Label windage tray includes a black oxide finish for long oxidation free life and installation instructions.
Quick Reply: ls3 stroker w/ gto oil pan cover / scraper not fitting
