Wet sleeve question
There are a lot of old iron SBC and BBC engines running around with replacement sleeves using standard coolants. Will be interested in seeing why this would not be an option for LS engines.
LS1TECH Sponsor
Fresh water cooling
Normally you would need some sort of anti rust additive in the coolant to keep the exterior of the sleeves from rusting. Darton has phosphate coated sleeves that may work for a while. The reason I say for a while is the sleeve flats and coolant holes through the flange are machined after the sleeves are coated so those areas are bare metal and will rust. I wouldn't recommend trying this in a boat with salt water cooling for that reason.
Steve
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Steve Demirjian
Oceanside, Ca.
760-630-0450
