Ditch Maggie and go H/C?
I currently have an LS2 with older patriot 5.3 heads, Speed Inc SI5 cam 231/237 589/595 and a Maggie 112 with 90mm snout and FAST 90MM TB.
I am wondering if it is worth keeping the maggie on the car or should i go with a bigger set of heads and cam?
Realistically im guessing i should make somewhere around 500-550whp, maybe more and i see guys making around 500whp with a nice set of heads and bigger cam. And see good numbers with l92/l76 setups.
Any info would be appreciated, The engine is in a 71 Vega, 6-speed. I plan on doing alot of drag racing but will be street driving the car as well.
I'm not sure what the goal is here.
I'd sell the maggie for a centrifugal blower and easily eclipse 600rwhp.
A max effort heads/cam LS2 will see 515-525rwhp through a 6 speed.
A H/C/I car may hit close to the same rwhp that a maggie car does but never the rwtq that a maggie does. At least I have never seen one on 11:1CR.
My 2006 GTO stock LS2 M6 with Kooks 1 7/8" LT's with 3" spintech stainless steel exhaust, chrome Maggie TVS 2300 running 8 1/2 lbs put down 540/550 to the tire.
Why not just change the pulley and add more boost.
