RED LS2 Resleeved 434ci vs LS3 416ci (( Street car N/A & N2O ))
Was thinking about LS7 427 or LS3 416 with TFS headed but I heard bad things about LS7 block with stock sleeves when you add nitrous or boost
This car is an M6 car with 12 bolt 3.55 that will never see the track but only street car that I use it one night every weekend
Planning to do 200-250 shot progressively with C16 race fuel but as you know it will not be sprayed every time like a track car !! Most of the time will be raced N/A unless there is an 800 rwhp supra in the highway
- For the LS3 416ci ( 4.060" bore/4.000" stroke )will use EPS custom cam & TEA/TFS 235 and ported 102
- For the 434ci ( 4.155" bore/ 4.000" stroke ) will use EPS custom cam & TEA/TFS 245 and ported 102
Sure I would like to get Erik @ HKE to build the engine but cannot get him via phone or email ... Maybe I will PM him here
Would be much appreciated if I can find your experience with the strong of sleeved block along,Durability against LS3 416ci ?? any problems with gasket when running 4.155 bore ??
Thanks
Thanks
LS1Tech Premium Sponsor
We stock resleeved blocks from R.E.D. & can price you & build you a high end short-block. Checkout some of our data on the all new TSP short-block complete with a full cnc machining capabilities including block digitizing & cnc block blueprinting.
Not to mention we ship in about 2 weeks rather than waiting the typical months & months most shops are making customers wait. The difference is we stock over 200 block, roughly 50+ crankshafts, and 50+ different piston configurations for all kinds of applications.
Checkout the machine shop thread:
https://ls1tech.com/forums/generatio...ng-center.html
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
The only people still pushing the tired "cathedral port means better lowend and crisper throttle response" either do not know any better or are selling cathedral port heads.
I agree but I think that's the case with all the heads. Use a different cam with that TFS head and watch the power #'s. I have the TFS heads on my 402ci so I may be a little bias towards those heads but I know they make power because when my car was H/C/I full weight on the stock bottom end motor I was able to go 10.90@123mph. The car made 447rwhp and 403rwtq.
I was impressed with the CNC ls1 head and the TEA ported 243's...numbers are right there with the rest of them. hp/torque is what gets you down the track right?
http://www.hotrod.com/techarticles/e...t/viewall.html
awesome article!
awesome article!
I would opt for the 4.125" bore 427 to unshroud the valves regardless of which heads. A lot of them are running nitrous on that combo, but you're right on the LS7 blocks.
