Camaro SS LS3 swap into a G8 GT
Old 09-14-2011, 08:28 PM
HotRodG8's Avatar
Default Camaro SS LS3 swap into a G8 GT
Im hoping i can have somebody help me with this, ive done all the searches on numerous forums and sites and cant find the info im looking for. I want to know whats involved in swapping a camaro LS3 in a G8 GT? ECM change? tuning? etc... nothing crazy...
just a straight up L76 to LS3 swap. im hoping that with all the knowledge here somebody will be able to tell me or direct me to someone who can. thanks
Old 09-15-2011, 04:56 PM
Chevyratracer's Avatar
I'm not positive but it shouldn't be much more than a tune and alot of work. If your looking for more power I think it would be easier to change cams and a DOD delete kit.
Old 09-15-2011, 11:10 PM
litle88's Avatar
I'm with him^^^
delete the dod, get some Ls3 heads, call new era about a cam and their new breakthru in Cam phasers. Fast 102/102, 1 7/8 headers a good tune and you'll be pretty damn close to the 500+ hp mark if not higher.
Old 09-16-2011, 04:12 PM
hivoltagedriver's Avatar
The L76 has the LS3 heads and intake. It is a 6.0 instead of a 6.2, and it has the DOD cam. A cam swap could EASILY make more power than an LS3 swap, and be a hell of a lot cheaper.
If you insist on the LS3, your stock ECM would work, it would just need to be retuned. Re-use all of your accessories and bolt it in.
Old 09-16-2011, 11:36 PM
Bring the Noise's Avatar
Run a cross check on front accessories and see if they are interchange able.
I don't think the oil pan is the same though (I think GM redesigned the Gen 5's front end -vs- the original G8/Holden platform).
Retune (AFM/DOD delete) and a crank relearn on the ecm (both use the 58x crank timing gear).
Swap to premium fuel (11:1 LS3 vs 10:1 L76)
You will gain 12 cubes (364 to 376) and higher compression.
Neither motor had VVT, so cam phaser tuning is not needed...
Good luck.
Old 09-17-2011, 09:35 AM
HotRodG8's Avatar
The reason I am this swap is because I already have a,LS376/480 motor from another project, so its not a question of money. I talked to vector yesterday, those guys were awesome!!! They said its a straight swap, but I'll have to use my oil pan and pickup. Not wanting an all out beast, just a fun 400hp daily driver....
Old 09-17-2011, 04:03 PM
Mike454SS's Avatar
Yeah, electrically it's compatible if you tune the car...you'll need to swap out some minor parts...but it's going to really wake your G8 up (based on what I've seen on the dyno between my own car and some G8 GT's) and you can probably sell your L76 from your G8 for a good chunk of change.
Old 09-17-2011, 08:25 PM
jsmith564's Avatar
a fun 400hp daily driver can be had w/o swapping motors. the 6.0 is more the capable of 400rwhp. why would you swap engines for just 400hp? that would be a wast imho
Old 09-18-2011, 09:57 AM
HotRodG8's Avatar
I'm swapping motors because, I dropped a valve in my 6.0....
Bad engine...
Quick Reply: Camaro SS LS3 swap into a G8 GT
