Cam to big for springs?
Old 09-14-2011, 09:19 PM
Droptoplt1ta's Avatar
Default Cam to big for springs?
I just had a spring break on my setup.
I have L92 heads with the PAC 1518 springs. I bought these heads used which owner stated they had about 1k miles on them (they were clean and in good shape). L76 engine.
I installed them and a cam of the size of 231/236 .641"/615" 112lsa, and engine ran ok for almost 1 hour of total run time, and then I got a noise and found a broken spring.
Is that cam to big for these springs. Any idea for cause of failure?
Thanks
Old 09-15-2011, 11:33 AM
Unaffliated Racing's Avatar
Considering that it coil binds at .660", I'd say yes. Single spring, big valve, too much lift.
Old 09-15-2011, 11:34 AM
SNLPerformance's Avatar
Yeah, that super aggressive LSK lobe combined with a big/heavy L92 intake valve definitely needs a dual spring, hopefully damage wasn't too bad.
Old 09-15-2011, 12:03 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
You need something like the PRC Double .650" spring kit.
http://www.texas-speed.com/p-474-pre...pring-kit.aspx
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 09-15-2011, 12:04 PM
we have some stock valves in case you hurt one, give us a call if you need a spare!
__________________
Jason
2005 Twin Turbo C6
Old 09-15-2011, 03:10 PM
TurboBuick6's Avatar
If you want to keep PAC's on there many vendors on here including Texas Speed carries our new small diameter duals.
Old 09-16-2011, 06:26 PM
I see the PAC 1518 springs are rated to .650, so I figured I was ok when I bought these heads..... Also, it was an exhaust spring that broke - I see the intake on this cam has more lift than the exhaust...
Thanks Jason. I will likely be calling you guys soon to take you up on that!
Old 09-17-2011, 02:28 PM
An exhaust valve broke? Its less lift on my cam
Quick Reply: Cam to big for springs?
