862 heads worth touching?
Old 10-09-2011, 12:23 AM
ToxicWS6's Avatar
Default 862 heads worth touching?
so i have a set of stock 862 castin heads off a 5.3 l sierra that have around 30k miles on them are they worth sending off to get port and polished and maybe milled for a stock internal ls1?
if i can/should mill them with maybe plans of an ms3/4 cam ( or simliar cam) in the future what would be a safe amount, thanks!
Old 10-09-2011, 10:05 AM
1lejohn's Avatar
They are good heads for high compression builds. I think they already have a small chamber. They are not worth spending a lot of cash on. I would do just a basic rebuild. Seals , springs maybe a valve job or just hand lap the stock valves.
Old 10-09-2011, 12:19 PM
ToxicWS6's Avatar
im just thinking if i can save $1k on heads would help me alot atm if i can just send these out to the machine shop and get them to get the heads to flow a little better to get more out of them but
Old 10-09-2011, 12:20 PM
Tainted's Avatar
ported 243s FTW
Old 10-09-2011, 07:55 PM
oldguy99Z's Avatar
Just wanted to point out in case you don't know 862 heads have a smaller intake valve(1.89) than all the 5.7 heads.If you buy ported 5.3 heads these are replaced with larger valves and the chambers are worked around them.I don't think I would bother with the 862 heads if you don't want to change the valves but it will increase your cost a bunch.
Old 10-09-2011, 09:35 PM
Spellbound's Avatar
I have a set of 862's that TEA worked their magic on (6 years ago) and I still like them a lot, lol.
Old 12-06-2011, 11:17 AM
Rare96LT1Formula's Avatar
Also curious about what kind of #'s can be produced with worked over 862's, ms3/ms4/torquer v3 type cam and full bolt ons.
Old 12-06-2011, 11:26 AM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
Those heads do pretty well once ported and with a larger valve. The stock valve is pretty small so its almost a requirement that you get some larger ones in there. We have been porting these heads for quite some time with good success. My last car had a set of our PRC 5.3l heads and an MS3, I was able to make 475rwhp and 412 rwtq. See my sig for the rest of the mods. You can send your heads to us if you would like us to CNC port them for you.
Old 12-06-2011, 03:51 PM
Are the PRC Stage 2.5 5.3L heads you guys sell touched up 862 castings? Can you PM me a quote for sending in my 862's, full cnc port/polish, new upgraded valves and springs? Ideally, I'd like to run the Torquer V3 cam but only if I can match it well with the heads I choose.
Old 10-30-2012, 11:42 AM
CheapStreet101's Avatar
How did this ever turn out? I was wanting to do this same build.
Quick Reply: 862 heads worth touching?
