Ls2 402
Old 10-18-2011, 04:49 PM
06SpiceRed's Avatar
Default Ls2 402
Just recently had 402 internals installed now I'm almost done the break in,and i have a very loud tapping noise coming from the engine any idea of what it could be ?
Old 10-18-2011, 06:10 PM
Jimbo1367's Avatar
Any videos?
Old 10-18-2011, 07:30 PM
06SpiceRed's Avatar
No don't have any right now but can post some. But any idea without video ?
Old 10-18-2011, 07:34 PM
westtexasbuff's Avatar
Might be best to contact the person who built the motor... just sayin.
Old 10-18-2011, 07:59 PM
SpinsB's Avatar
more info or video would help us give more input
Old 10-18-2011, 08:30 PM
06SpiceRed's Avatar
I will post a video , but the only other info i have is the tapping is coming from both sides of the engine while driving or at idle . The 402 build has about 3k on it , the only thing that comes to mind is the Harland sharp rocker arms coming loose ? If that's possible
Old 10-18-2011, 08:35 PM
ChucksZ06's Avatar
Some things can only be determined in person...waste of forum members time and your time also. When an engine assembly is screwed up you or someone will have to take it apart until you determine the problem...hell of a learning curve though. Good luck.
Old 10-18-2011, 09:00 PM
Tainted's Avatar
Rockers, lifters, valves even...
Old 10-19-2011, 07:21 AM
odarabla's Avatar
If it's coming from the side of the block it could be a spun rod bearing. I have the Harland Sharpes on my car and it sounded more like a sewing machine then a knock. Then I spun a rod bearing and could def tell over the sound of the Harland Sharps..
Old 10-28-2011, 08:28 PM
leong6gtp's Avatar
Who built the 402?
Old 11-05-2011, 01:55 PM
Jimbo1367's Avatar
Originally Posted by leong6gtp
Who built the 402?
I built it. Why do you ask? I stayed in a Holiday Inn the night before.
Quick Reply: Ls2 402
