Texas Speed PRC LS7 Heads
Old 10-26-2011, 12:39 PM
Unreal's Avatar
Default Texas Speed PRC LS7 Heads
One of my heads showed up today. UPS still has the second head.
Old 10-26-2011, 01:13 PM
Unreal's Avatar
More shots.
Old 10-26-2011, 01:54 PM
DietCoke's Avatar
My small bores should be here verrrrry soon. What size are these?
Old 10-26-2011, 02:41 PM
built408's Avatar
pics of the intake port?
Old 10-26-2011, 02:47 PM
venom ws7's Avatar
Great price , great quality and will make great power...
We've made 595rwhp with those heads with QM600 cam on N/A C6 ZO6 on 91octane
What's your engine setup??
Old 10-26-2011, 02:52 PM
Unreal's Avatar
Will take more pics when I get home.
They are the 285CC LS7 heads.
Engine is an LS7, Comp 228/236 .637/.640 115LSA cam
A&A Vortech kit Si-trim
LG 1 7/8" headers
Fast 102 Intake
Etc
Stock bottom end for now. This time next year I'll do a nice forged motor and crank up the boost.
Old 10-26-2011, 06:10 PM
Unreal's Avatar
Now the question is copper spray or not? Using ARP bolts with stock ls7 gaskets. I cleaned the block as well as I could. Texas speed and local shop said to hit the gaskets with a light coat of copper spray. My local friend who did heads did his dry.
Old 10-26-2011, 06:21 PM
Unreal's Avatar
Old 10-27-2011, 06:33 PM
Jimbo1367's Avatar
What are the specs of a QM600 cam
Old 10-28-2011, 08:19 AM
good2go's Avatar
I'm running those heads, milled .030" and that cam. Best RWHP is 572 SAE on a dynojet. What's the rest of your combo to get 20+ more rwhp? I know some dyno's are more stingy than others, but 20 rwhp! I'm running the stock but ported TB and intake manifold, and AR headers, no cats.
Old 10-28-2011, 10:05 AM
venom ws7's Avatar
I'm not really sure this is what they have in the website
23X/25X 6XX/6XX 113lsa
Fast 102 intake, Fast 102mm TB and Corsa extreme catback.
dynojet dyno numbers were SAE on 91octane around 80f weather.
Old 10-28-2011, 10:19 AM
Unreal's Avatar
Don't worry too much about dyno numbers. My friends car with a Lethal cam, 232/250 .660/.660 113 made 560rwhp on the dyno with stock heads milled .030". Different dyno on a nicer day with a bit more tuning made 578rwhp.
One head is on. The other head should go on tonight. From there I can get all the other stuff installed. Still have to measure for pushrods.
Old 10-28-2011, 08:01 PM
ramairws6's Avatar
I have a set of stock LS7 pushrods if needed.........
Old 10-29-2011, 06:08 AM
Unreal's Avatar
So do I since these are going on a 2006 z06. Texas speed said they would be longer but I keep measuring right around stock which caliper out at 7.82. I'll go measure again once it warms up in the garage but I think they are going to be just about stock length.
Old 10-29-2011, 06:36 PM
Unreal's Avatar
For reference I measured a 7.825" pushrod to go with these heads on my LS7 with a comp cam.
Old 10-30-2011, 06:58 PM
Unreal's Avatar
Old 10-31-2011, 10:14 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Keep in mind stock gauge length was about 7.780" or so. So you're about .050" longer or so!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 10-31-2011, 10:36 AM
Unreal's Avatar
Matt, does that sound right? You said they should be a bit longer then stock because of the thicker decks.
Old 10-31-2011, 11:26 AM
It's not really because of the thicker deck, but rather because we moved around the ports, valves, pushrods, etc in the head and needed to move the pedestal up in the head to make more room. That raised position is why you need a longer pushrod
__________________
Old 10-31-2011, 11:52 AM
drenner43's Avatar
Nice!!!
Quick Reply: Texas Speed PRC LS7 Heads
