Warhawk 481 talldeck build!
Old 10-28-2011, 09:01 PM
79ta455stroked's Avatar
Default Warhawk 481 talldeck build!
Hey guys have a cpl questions for anybody or builders that have done a warhawk 481 build!
Combo is
talldeck warhawk ls7 block
4.125 bore
4.500 stroke
6.440 rod
9.800 deck
-19cc piston with 1.115 comp height
Wld be 10.7:1 with 72cc head,11.5:1 with 64cc head
****U guys have any trouble with rod/cam clearance with this combo?
I have not picked heads or cam yet so also looking for suggestions.
Not lookin for a all out max effort build here,gonna be a street/roadcoarse car.
I do have a cam laying around,wanna see what u think about it for this combo
its a hyd roller:
.246/.254 @ .050
.613/.613 lift
115 lobe sep
Thanks!!
Ohh btw,goin in a 1987 C4 VETTE!! LOL
Old 10-28-2011, 09:11 PM
SSPerformance's Avatar
You should go with the RHS block has a raised cam
Old 10-28-2011, 09:18 PM
Already have above shortblock!
Have not checked cam clearance yet,just wondering if others know if there is a problem with standard basecircle cam?
And then suggestions on cam/head.
Thanks!!
Old 10-28-2011, 09:22 PM
3.8redbird's Avatar
pics of this c4 please. sounds wicked
Old 10-28-2011, 09:25 PM
Shawn @ VA Speed's Avatar
yeah, you are going to have cam to rod clearance issues.
Old 10-28-2011, 09:33 PM
Thanks fo the response man!!
How bad? Any cylinders in particular?
This might be a dumb question but im new to the ls world,Do they make small base circle cams for these things?
Old 10-28-2011, 09:35 PM
Car is half apart as im halfway through a 91-96 body style upgrade,complete paintjob,and c6 z06 brake upgrade so pics rite now wldnt be pretty! lol
But ill update as i go along!
Old 10-28-2011, 09:40 PM
3.8redbird's Avatar
What transmission are you going to use? D44 or custom 9inch I hop is backing this.
Old 10-28-2011, 09:45 PM
Have a D44 out back.
Dont think my 4+3 4 speed tranny will live very long behind this so goin with a T56 6 speed.
Old 10-29-2011, 01:42 AM
Sawzall and Welder Mod
Whistler's Avatar
What kind of rods?
Old 10-29-2011, 06:48 AM
Originally Posted by Whistler
What kind of rods?
callies crank
callies compstar rods (2.00 journal)
diamond pistons
Old 10-29-2011, 08:24 AM
it's going to be pretty bad, even with the 2.00 journal. small base circle cams are made but you need to be careful with the lifters at that point
Old 10-29-2011, 08:50 AM
Thanks for the help man!!
Any thoughts on the cam i listed above?It was in a warhawk 427ci combo but thinkin about using it for this combo if i dont need a small base circle cam.
Im guessing im gonna need to have this rotating *** balanced again after clearancing rods for cam?Or maybe it will jst be a cpl grams id be losing?
I have the good lifters with tie bar.Brand is escaping my head rite now!lol
Quick Reply: Warhawk 481 talldeck build!
