LS3 water pump heater out and inlets - needed?
Old 11-04-2011, 06:37 AM
corvettedave's Avatar
Default LS3 water pump heater out and inlets - needed?
Ive got a new LS3 for racing offroad 4x4 car, dont need heater in it, what can I do with the waterpump in/out for heater, someone said they should be pumped into a heater, if you dont that can affect engine cooling, etc
thoughts please?
dave
Old 11-04-2011, 07:53 PM
S10xGN's Avatar
You'll get mixed opinions. Most say blocking them causes bypassing the radiator. I have mine going to a heater core, but the valve for the heater is a "positive seal" block valve, so what's the difference? I have no issues at all...
Old 11-04-2011, 08:08 PM
DietCoke's Avatar
Pumping them into a heater does nothing. You can remove them, or loop them.
Old 11-05-2011, 04:05 AM
rsz288's Avatar
Thermostat operation does wierd things if they are blocked. Looped and the tstat and cooling system operates normally. If they are blocked then the tstat sits in a "cold" spot of static water which causes late opening of the thermostat at low speeds with excessive heating and then excessive cooling at higher speeds. This is with a factory stat at least.
This is why the factory setup has water flowing between them at all times with a bypass type heater control valve.
Old 11-05-2011, 06:57 PM
Thanks for help guys
is it ok to use a 4 inch piece of rubber hose or does it need to be longer?, I wouldnt of thought it would make any difference?
cheers
dave
Old 11-05-2011, 07:45 PM
rsz288's Avatar
cheers
dave
As long as water flows through it, it doesnt care. Maybe you can find a molded u turn hose that will fit.
Old 11-06-2011, 06:48 AM
garys 68's Avatar
I'm running mine with a heater control valve which effectively blocks it. No problems. In modern cars, there is always flow through it though. Also marine versions loop the inlet/outlet, so I do believe it works better with flow through it all the time.
If you search the conversions forum, there's a part number for a loop hose.
Old 11-06-2011, 08:11 AM
many thanks guys
cheers, dave
Quick Reply: LS3 water pump heater out and inlets - needed?
