LS7 with a LS6 oil pan swap in a 98 vert.
Old 11-28-2011, 01:56 PM
man2004's Avatar
Default LS7 with a LS6 oil pan swap in a 98 vert.
TEC is putting together a LS7 (wet sump/24 reluctor) to swap into my 98 TA convertible. The LS6 pan fits nicely on the LS7. But, I am not sure if there will be a fitment issue in the F-body convertible. Does any one know if the LS7 with a LS6 oil pan will fit in the TA?
Old 11-28-2011, 02:11 PM
ramairroughneck's Avatar
Can you specify if its a corvette batwing or ctsv oilpan. I think theyre different. Might try this thread. It has some measurements.https://ls1tech.com/forums/conversio...-oil-pans.html
Old 11-28-2011, 02:17 PM
man2004's Avatar
Good point! The oilpan was removed from a CTSV.
Old 11-28-2011, 02:26 PM
man2004's Avatar
I am wondering if the 6 and 3/4" (CTSV) vs. 5" (F-body) oilpan depth will be the problem...
Old 11-28-2011, 04:00 PM
Sawzall and Welder Mod
Whistler's Avatar
Why not just run the F body pan?
Old 11-28-2011, 04:13 PM
man2004's Avatar
The engine builder (TEC) is throwing in the LS6 CTSV pan at no additional cost. And, I was trying to keep the LS1 complete for resale purposes since it will still have the intake, TB, water pump, as well as the harness and ECU (I am also swapping the 1998 for a 2000 ECU and harness). But, if the LS7/LS6 CTSV oilpan combo will not fit, I might have to use the LS1 pan.
Old 11-29-2011, 06:28 AM
man2004's Avatar
So, are there any other options besides the F-body oil pan for the LS7 swap?
Old 11-29-2011, 07:06 AM
Whistler's Avatar
Aftermarket pans. I personally would just run the OEM Fbody pan since it works well for the street in regards to clearance.
Quick Reply: LS7 with a LS6 oil pan swap in a 98 vert.
