ls2 piston flycutting ?
Old 12-03-2011, 11:53 AM
Z284thgen's Avatar
Default ls2 piston flycutting ?
i have all ls2 internals in my iron block ? is how much can i fly cut them with out creating any probs new heads are gonna have a 2.02/1.60 valve with 60cc chambers .611/.609 lift
Old 12-03-2011, 12:01 PM
Turd Gen Guy
1nasty86's Avatar
Originally Posted by Z284thgen
i have all ls2 internals in my iron block ? is how much can i fly cut them with out creating any probs new heads are gonna have a 2.02/1.60 valve with 60cc chambers .627/.639 lift
Need all the specs on the camshaft
Old 12-03-2011, 12:19 PM
Z284thgen's Avatar
238/240 108icl 112lsa gonna have a .041 mls gasket on it
Old 12-08-2011, 06:59 PM
Danny's Avatar
You can safely cut about .080" into the pistons. I've heard of some guys going to .100" but IMO that's on the edge especially is you're adding spray.
You need to measure in order to know exactly how much you'll need to flycut.
Old 12-08-2011, 11:20 PM
Z284thgen's Avatar
it will get checked before cutting but im looking for how safe can i cut the pistons lord i sure hope i dont have to cut .080
Old 12-12-2011, 10:17 AM
Danny's Avatar
You should be pretty safe @ .080" I wouldn't worry about it. Are you going to be spraying the car?
Old 12-12-2011, 11:16 AM
Z284thgen's Avatar
at a later time it might get 150-175 on a plate only if i cant get the ET i want outta poor ol FOX car
Old 12-12-2011, 05:20 PM
Danny's Avatar
You're going to be close to the edge with that much. You have to remember, these pistons are not forged and removing material only weakens them. I'm not saying it's going to blow up right away. I'm just saying you're going to be on barrowed time. Then again, anytime you're racing you're on barrowed time. Just make sure when you put the bottle in that the nitrous tune is on point. Be conservative with the timing.
Old 12-12-2011, 09:01 PM
CAMSTER's Avatar
This is what i would do, will install the cam and bolt on the driver side head, after putting modeling clay on the pistons, at lest 2 of them,torque it and install all the valve train, as ready to run, turn the motor and remove the head check the clearance, in my experience, there was more clearance there than anticipated, in all tested cases...
Old 12-13-2011, 12:01 AM
Z284thgen's Avatar
current setup has a lil of .050 clearance im hoping with new heads i dont have to cut more then 25-30
Old 12-13-2011, 09:06 PM
CAMSTER's Avatar
Default If a different cam...
You may not have to cut at all, cause the valve timing may be different all together...
Quick Reply: ls2 piston flycutting ?
