Double taper pushrods/L92 heads Q?
I haven't been able to find this info by searching.
Question is regarding an L92 headed/LS2. Heads are milled .030", .040" gaskets, stock untouched shortblock.
I have found information stating that straight 3/8" pushrods will work with slight clearancing to the cylinder head.
I have not been able to find an answer pertaining to the fitment of a 7/16" to 3/8" double taper pushrod though. Will this fit with similar clearancing or does it not slim down quickly enough? I'm aware this is most likely overkill for my setup.
