To get 11.0 CR, what mill value required L92 head
I want to have 11.0 CR with L92 heads. Thus to what value needs the heads to be milled?
You are right
You deserve more details
The engine specification:
-Bore: 4.0845"
-Stroke: 3.622"
-Cylinder Block: LS1 re-sleeved
-Cam shaft: 227/239 114LSA
-Heads: L92 (Casting 823)
-Melling Oil Pump (295)
-LS7 Lifters
-Trickflow double timing chain
-LS3 instake manifold with LS3 fuel rail and injectors
-102mm throttel body
-Bore: 4.0845"
-Stroke: 3.622"
-LS7 Lifters
Greeting
The piston's are flat (original LS3), ooohhh sorry, I ment to say the larger size of the LS3 piston (4.0845") flat type
as far for the gasket, it will be original thickness (I think it is 0.052")
Thanks...
Thanks...
Sorry, I made a typo mistake
it is the LS3 piston of larger size (4.0845") and it comes flat.
There is a softwear that calculate for you the compression but it is a trail version which is expired.
Thanks
Thanks
http://www.wallaceracing.com/cr_test2.php
There are more here too....
http://www.wallaceracing.com/Calculators.htm
If u use ls9 gaskets.
The scr will be 10.86:1
Assuming out the bore is .010
Assuming pistons are flat without a dish or any relieves
To get 11:1 on this motor. Only need to mill about .005
Off the heads.
Based on the info you provided and values missing that I aasumed.
But its not certain, unless you have exact values for all 5V
V1 4.0845x3.622
V2 70cc
V3 4.0845x.010
V4 4.1x.051 (LS9 head gasket)
V5 0
= 10.86:1 SCR
To gain 11:1 from this motor. .005 must be removed from the cylinder head surface.
Off the heads.
V1 4.0845x3.622
V2 70cc
V3 4.0845x.010
V5 0
= 10.86:1 SCR
Do you have a part number for those overbore LS3 pistons?
Remember if using an aggressive long duration, high lift cam.
PTV clearance must be verified before any machine work on heads.
This will determine if pistons will need valve relieves cut in pistons, then must find value of relieves.
This will change V5 if so. More than likely if using real flat top piston.
Then can proceed to find value of amount need to mill off cylinder heads.
It will be more than previous mentioned .005 if relieves are cut in pistons.
I wouldnt/dont have any machine work on heads unless I have my cam card in hand to find the dcr/scr im looking for. And then proceed to have any machine work on heads or pistons.
I prefer to use .015 out the bore for every build if.possible and use .050 compressed gasket if possible to achieve .035 quench
The cam is 227/239 --- 0.613/0.623 LSA 114 ICL 114
With the above cam & milling the head to 0.030", will the CR be around 11.1? Will the pistons require notching with heads milled to 0.030" with the above mensioned cam?
LS1 Tech Administrator
About .006" (six thousandths).
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
