Cam wont come out, Problem?
I was in the process of pulling the cam out of my LY6, and it wont budge, it will spin around pretty easy put I could not get it to pull out at all. could this mean something or should I just try to put some more muscle behind it?
Lifters have to be up out of the way for the cam to come out. The lifters, on base circle or on the top of the lobe, still hang down lower than the cam journals and will not let it come out. You need to spin the cam several times and let the lifters get pushed up out of the way and then use some means of keeping them there because the cups dont always hold them. Ask me how I know.
And as 97 said, once the retainer and the lifters are out of ht way it should slide right out the front. What I did is bolt the cam sprocket back on to give me something to hang on too so I could get it started.
Like said above...pull pushrods and spin motor over. Lifters trays with their angle create enough friction to hold. But please put 1/4" dowels in holes on each side of cam to prevent them from dropping into motor once cam is removed!
- Jeremy
Ok guys, sorry for being such a newb but I know what the problem is. I didnt know you had to remove the rockers and pushrods. They skip that step in the Haynes manual. Thanks for your help
The Haynes is good, but they do leave out a bunch of stuff, and are vague on others. There is a great write-up over on Camaro5, with somebody swapping a cam in an LS3, different engine, but basically the same. You can check it out here: www.camaro5.com/forums/showthread.php?t=125123
- Jeremy
- Jeremy
I saw pics of a guy that used 16 telescopic magnets and 16 clothespins.
He stuck the magnets to the lifters and clipped the clothespins on to keep them from dropping back in.
Looked like a clever (but expensive) idea.
...and DON'T squeeze too hard when you're holding the cam...the edges of the lobes are sharp...easy to cut your hands if you're not expecting it.
