Someone burry the hatchet.....DOD vs VVT oil pumps!!
Old 01-29-2012, 06:46 PM
csilvers1984's Avatar
Default Someone burry the hatchet.....DOD vs VVT oil pumps!!
Lol "BURRY the hatchet" anyhow I've spent some time searching and asking around about which oil pump is better as a replacement. I cannot get a straight answer!! So which pump is high volume? DOD or VVT? Is one high pressure? I'm buying a new pump this week and want a higher volume pump for my 402.
Old 01-29-2012, 06:52 PM
futureuser's Avatar
http://www.melling.com/Aftermarket/H...mOilPumps.aspx
Old 01-29-2012, 06:53 PM
litle88's Avatar
If I were you bud, why mess around and get a melling? It will just drop right in. Unless you don't like them that's another story.
Old 01-29-2012, 08:40 PM
I have a melling m295 pump that came with the motor. I was told the melling pumps had a problem with the gear scoring the inside of the pump.
Old 01-29-2012, 11:36 PM
litle88's Avatar
I've never heard of that got some links? I've had mine for 3 seasons and about 10k miles that thing is faithful with its psi especially at start up lol hot or cold it's 60 psi at start up.
Old 01-29-2012, 11:57 PM
I dont have anykind of link,just heirsay man. The melling pump have always been regarded as a good pump.
Which pump are you running? High pressure or high volume? Also which spring are you using in the pump?
Old 02-01-2012, 09:20 AM
LS1Tech Sponsor
Slowhawk's Avatar
We always use a stock pump 04 Vette and port/shim .100" the pumps. Never had a problem with them with some going 80k + miles on strokers.
Old 02-01-2012, 09:32 AM
87silverbullet's Avatar
^^^ this right here has work sucessfully for years . I don't see the point in trying to re-invent the wheel here.
Old 02-01-2012, 08:38 PM
I was clearly looking for the GM pump that is higher volume. Its not re-invetion but rather sorting out the facts.
From what ive gathered the lsa pump is the higher volume GM pump.
Old 02-01-2012, 08:44 PM
Why do feel that you need more volume?
Old 02-01-2012, 09:07 PM
10 Second Truck Club
67SS509's Avatar
Read this thread..... http://www.norotors.com/index.php?topic=10219.0
Old 02-02-2012, 09:23 PM
Originally Posted by 67SS509
Yea haha ive seen it! Good info and helped me make my pump decision.
Quick Reply: Someone burry the hatchet.....DOD vs VVT oil pumps!!
