LS3 rocker scrub pattern with stock rockers, big cam?
Old 02-03-2012, 09:48 AM
Jim85IROC's Avatar
Default LS3 rocker scrub pattern with stock rockers, big cam?
I'm assembling my 402 stroker with LS3 heads, and today I measured my pushrod length. In the process I decided to throw a stock pushrod in (very close to the length I need) just to check the scrub pattern of the rocker on the valve. What I found really surprised me. The scrub pattern was very wide. Is this normal with stock rockers? I'm guessing it is because the rocker surface is flatter than that of a roller tip?
Has anybody else checked this with stock LS3 heads and stock rockers? For what it's worth, my cam lift is in the .615 range.
Old 02-03-2012, 10:13 AM
Jim85IROC's Avatar
Based on Brian's comments here, it sounds like this wide sweep is normal:
https://ls1tech.com/forums/13879292-post9.html
Old 02-03-2012, 10:24 AM
-TheBandit-'s Avatar
How much lift are you running?
Old 02-03-2012, 10:28 AM
Jim85IROC's Avatar
.613 intake, .617 exhaust.
Old 02-03-2012, 02:32 PM
chrisfrost's Avatar
My 5.3L with LS6 cam has a scrub pattern that is maybe .040" narrower than that pattern in the pic ,,,,,,,,,but I would assume that the wider pattern would wear longer with less pitting or ?
Old 02-03-2012, 05:01 PM
3pedals's Avatar
I am running ALOT more lift than .615" and my scrub appears good, I will be re checking upon assembly this coming week
Old 02-03-2012, 06:53 PM
briancb1's Avatar
First off, what type of lifters and springs are you using for these tests you're performing?
Hydraulic lifters and the springs I see above I assume?
If you're trying to perform a sweep patter at lease use a checker spring that wont bottoms out your lifter.
Old 02-03-2012, 07:27 PM
S10xGN's Avatar
My thoughts are: the smaller the wipe pattern, the less side loading on the valve stem and thus, better longevity.
Quick Reply: LS3 rocker scrub pattern with stock rockers, big cam?
