dry sump pics? which peterson tank u runnin?
Old 02-12-2012, 10:13 AM
7second's Avatar
Default dry sump pics? which peterson tank u runnin?
any engine pics with dry sumps? which peterson tank you guys runnin? I'm thinkin the 1.5gal drag race one but dunno if 6 qts is enough for street use
Old 02-12-2012, 04:00 PM
Firehawk441's Avatar
I use the moroso tank with an ARE pump and pan
Old 02-12-2012, 05:23 PM
7second's Avatar
nice, who makes that alternator bracket? bmr?
Old 02-12-2012, 05:52 PM
Correct. BMR. I had to remove .250" from it to compensate for the motor plate.
Old 02-13-2012, 06:18 PM
Louis's Avatar
Id use more than the 1.5 gallon. Even though the stock pan holds that, Id look into atleast an 8 quart setup.
Old 02-13-2012, 06:56 PM
1.5 gallon tank works fine for me.
Old 02-13-2012, 08:39 PM
Gray86hatch's Avatar
Whos motor plate is that
Tim
Old 02-14-2012, 05:41 AM
Tim
KTS Race Cars.
http://www.ktsracecars.com/motorplates.htm
Old 02-14-2012, 12:54 PM
7second's Avatar
I like the petersondrag tank with integrated catch can. But it only holds 6quarts. I think atleast 2 gal would be better with a turbo motor and heat. Guess running a seperate catch can isnt bad
Old 02-14-2012, 03:01 PM
studderin's Avatar
No Tstat?
Quick Reply: dry sump pics? which peterson tank u runnin?
