LS1 rockers on LS3 heads. Would you do it?
Is this a bad idea? I know the rocker stands themselves are different between the LS1 and the LS3, but I'm seeing the same P/N for both the LS1 and LS3 rockers themselves.
I guess my question is, it seems like it should work, but would you use OEM LS1 lifters on a LQ4 408 w/ LS3 heads and a cam so big it comes with a surgeon general warning? "Caution: may cause loss of bladder control when accelerating" Oh, also I'll be using LS7 lifters.
the exhaust rockers are the same, the intake rockers will not work. the intake rockers of the LS3 heads are offset. you will never get them bolted on even if you try.
the shitty part about it is, since the LS3 style heads are still fairly new, people are wanting an arm and a leg for stock LS3 style offset intake rockers. good luck, i'm in the same sinking boat. lol
So, it seems that the exhaust rockers from the LS1, and the intake rockers from LS3, on LS3 stands "should" work, right?
http://www.lingenfelter.com/mm5/merc...gory_Code=C216
Bob K.
