How much will be left on the table with.....
Old 02-19-2012, 08:42 PM
TurbopigB4C's Avatar
Default How much will be left on the table with.....
Stock 317 heads instead of AFR 230's or Trickflow 225's on a 416 ci build with 223/231 cam?
Old 02-19-2012, 11:24 PM
litle88's Avatar
Quite a bit, I'd say. Why such a small cam?
Old 02-20-2012, 08:53 AM
CA smog emissions. I plan on installing the two piece timing cover to swap in a bigger one later. I figured the stock heads with the small cam and stock ls1 intake manifold would not hurt the 416 that much. If I were to go with a real big cam the intake and heads would hurt me a lot more I would think as I would reach the limit of flow for my setup as is.
