Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Generation IV Internal Engine
Sign in using an external account
Register Forgot Password?
2005-2010 LS2 | LS3 | LS7 | L92 | LS9
Sponsored by
Mast Motorsports
Thread Tools Search this Thread
Old 02-21-2012, 11:44 PM   #1
Garage is empty, add now
Outlaw E36's Avatar
Trader Rating: 10
Default Mighty l92/ls3
Since Im having trouble selling my shortblock I was condering doing a budget build with L92/ls3 topend. I just want to hear some opinions or feedback to see if its worth it.
Iron block bored out to 4.060
Off-set ground eagle crank to 3.70
6.25 eagle forged rods
Ross 8cc flycut reliefs
Ls7 lifters
Custom cam
Outlaw E36 is offline   Reply With Quote
Old 02-22-2012, 12:48 AM   #2
Trader Rating: 27
No need for the offset ground crank. Thats just to get every last bit of CI for your class thats allowed. If not done correctly it will weaken the crank and its not budget friendly. If you are buying an aftermarket crank already why not just go 4"? Also I would stick with a 6.125 rod simply for ease of piston selection. I would go with a nice tie bar lifter over the LS7 ones.
Pwebbz28 is offline   Reply With Quote
Old 02-22-2012, 01:07 AM   #3
Outlaw E36's Avatar
Trader Rating: 10
That's actually the current set up on my shortblock, Its already put together. Ive been reading a lot about L92/Ls3 making good number so I was wondering if it would perform well with my shortblock since I have a 4" bore
Old 02-22-2012, 05:12 AM   #4
1988 Pontiac Firebird
1badeagle's Avatar
Trader Rating: 8
Why are you boring it to 4.060? I went with a 4.030 bore on my build. YOur only gaining 6 ci with the extra .030". You will never notice the loss of 6 ci.
__________________
Another carbed 305+65
1badeagle is offline   Reply With Quote
Old 02-22-2012, 05:21 AM   #5
KCS
KCS's Avatar
Trader Rating: 14
Quote:
IMHO, it's the little things like this that make the difference. This one little thing may only be worth 5hp, but with four other things that make 5hp each as well and it adds up fast.
__________________
2000 Pontiac Trans Am - Heads/Cam 6.2L
1980 Ford Mustang Coupe - TBD
KCS is offline   Reply With Quote
Old 02-22-2012, 06:58 AM   #6
chuckd71's Avatar
Trader Rating: 14
But will you notice the total of those four little things? Especially given their cost, will you ever notice 20hp in a budget build motor?
__________________
Do not buy anything from Frankie's Used Auto Parts. Ever.
Chevelle almost finished - http://www.ls1tech.com/forums/conver...nvertible.html
chuckd71 is offline   Reply With Quote
Old 02-22-2012, 09:55 AM   #7
KCS
KCS's Avatar
Trader Rating: 14
Quote:
I would hope you could notice 20-25 more horsepower.
Who says they have to cost more? I went to a 4.060" bore and got the stock LS3 pistons for free when I most likely would have had to pay at least $200 for 4.030" pistons. Now I have 6 more cubic inches and my valve is further away from the bore wall.
__________________
Old 02-22-2012, 12:09 PM   #8
midevil1's Avatar
Trader Rating: 13
Amen!!! There is a reason GM bumped the bore from 4.0 to 4.065. The Ly6 makes 20 less HP than the L92. Only difference is the bore.
__________________
1967 Chevy C10 TT505 Pro street 4 digit power with 8psi... FASTER THAN YOUR VETTE..
1980 Ford FairmonTurbo 308, wife's Grocery getter. BITCH SLAPS YOUR VETTE..
1992 Mustang GT OUTLAW RADIAL CAR, CNC 598, Twin 91's...FASTER THAN YOUR VETTE..
midevil1 is offline   Reply With Quote
Old 02-22-2012, 12:33 PM   #9
Outlaw E36's Avatar
Trader Rating: 10
So would the L92/ls3 be a good topend with the shortblock.? I was considering milling the heads too.
L92 heads
Ls3 intake/fuel rails.
ls3 rockers and stands
92mm Throttle body
Old 02-22-2012, 02:44 PM   #10
Wnts2Go10O's Avatar
Trader Rating: 12
Send a message via AIM to Wnts2Go10O
interesting shortblock you built. an LS3 top end will do just fine. spec out the correct camshaft and itll do what you want it to.
__________________
89 Camaro RS: 6.0L, L92 heads, Patriot Golds, LS7 cam, Spec Flywheel, Ram Clutch, T56, Pro 5.0, Lous Short Stick, L76 Intake, Holley 90mm TB, 42LB delphi injectors, 255 Pump.
Quote:
Originally Posted by President George W. Bush
I think the national anthem ought to be sung in English, and I think people who want to be a citizen of this country ought to learn English and they ought to learn to sing the national anthem in English.
May 1 2011
Wnts2Go10O is offline   Reply With Quote
Old 02-22-2012, 02:53 PM   #11
midevil1's Avatar
Trader Rating: 13
Quote:
L92 heads
92mm Throttle body
I did a 4.065 iron block. L92 heads and LS3 intake race ported. 92mm TB. aftermarket valves and entire valvetrain. Diamond pop-ups. 11.5 to 1 on pump gas. made 504whp 489 TQ with the off the shelf Comp 231/239 cam. 1 7/8ths headers and dual 3 inch. SD tuned.
I would say you would be pleased with what they can produce. This was in a Daily Driver.
__________________
Old 02-22-2012, 07:41 PM   #12
Zbinkley's Avatar
Trader Rating: 0
This dyno is from my l92 headed 6.0. Very similar to what you are thinking of doing.
M6 car
Iron block 6.0. - stock cubes.
L92 heads milled to 64cc chamber.
TSP 233/239 .595/.605 114LSA
1-3/4 kooks longtubes
ls3 42lb/hr injectors
l76 intake
off brand 90mm throttle body
ls7 lifters
Dyno operator had to let off at 5300rpm due to driveline vibration. (later found out i had a dent in my driveshaft).
The rate of rise in hp over rpm im guessing it will be reeeeaalll close to 450.
And IIRC i had over .100" PTV at TDC.
Mighty l92/ls3-dyno_10-13-11.jpg
__________________
98 Z28 LQ4 Build Thread
Zbinkley is offline   Reply With Quote
Old 02-22-2012, 09:40 PM   #13
Zbinkley's Avatar
Trader Rating: 0
M6 car
l76 intake
ls7 lifters
__________________
Old 02-22-2012, 11:53 PM   #14
Outlaw E36's Avatar
Trader Rating: 10
This is very similar to what I had In mind. Who did the porting and how much did it cost you.? What was the cc on your heads.? I hope I get lucky and get good numbers like yours
Quote:
M6 car
l76 intake
ls7 lifters
Did you ever get to re-dyno the car.? Seems like a good set up
Old 02-23-2012, 12:29 AM   #15
1badeagle's Avatar
Trader Rating: 8
M6 car
l76 intake
ls7 lifters
How much did you mill to get 64cc chambers? .030"?
__________________
Old 02-23-2012, 01:51 AM   #16
midevil1's Avatar
Trader Rating: 13
[quote=Outlaw E36;15999899]This is very similar to what I had In mind. Who did the porting and how much did it cost you.? What was the cc on your heads.? I hope I get lucky and get good numbers like yours
Heads were stock CC and the exhaust was just ported at home.(I do Almost all my own machine work) I didn't see hogging out heads that flow 340's stock. Was looking to keep some type of velocity. I know milling to get compression is CHEAPER, but I have seen to many lose power by shrinking down the chamber. Pistons are always gonna cost more but I believe you will make more power. Especially when you are using a 2.16 intake valve.
__________________
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags
64cc, block, body, budget, build, differences, e36, l92, ls1, ls3, ly6, milled, milling, short, tech, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Advertising - Terms of Service - Privacy Policy - JOBS
Emails & Contact Details
